How to unlock Samsung T749 Phone info: ~~~~~~~~~~~ Phone Model: T749 Revision: T749UVIF3 IMEI: 3524940304**** Phone lock password: 00000000 SIM lock password: 00000000 Reading data from phone... ERROR - Can't read simlock data! thanks advice |
which software version you're use for unlock this phone ? please try to use latest software version or i think it is not supported phone for unlock |
I'm also tested it by read code tool with something CPU type. But not successfully |
Successfully unlocked with Z3X Put phone in qualcomm mode the same procedure of T919 Qualcom mode method (only usb): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB part of 2in1 cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes or Direct. 6. Press Unlock SP button. Samsung mode method (2in1 cable): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect 2in1 cable, setup drivers. 4. Choise port of RJ45 connector in port settings 5. Choise unlock method: Read codes or Direct. 6. Press Unlock SP button. Log: Model: SGH-T749 CountryCode: TMB Factory SW: UVIK1 UniqueNumber: 55690000****** MemoryPhone: K5R2G1GACC(T749)S IMEI: 359225030*****/* Phone S/N: RPESC08974 Build: SBAM6290A-KPVZL-1.2.0080_1U Reading SysInfo... error (Cant read Security data) Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:49) Freeze code: 80830485 NET lock: #7465625*638*90358509# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 Best Regards,:):):) |
[QUOTE=hoangtruongson;4762399]Phone info: ~~~~~~~~~~~ Phone Model: T749 Revision: T749UVIF3 IMEI: 3524940304**** Phone lock password: 00000000 SIM lock password: 00000000 Reading data from phone... ERROR - Can't read simlock data! seam problem how to unlock kindly help me Selected port: COM39 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM23 Reading phone info... Model: SGH-T749 Phone version: T749UVIK1 IMEI: 35257304216**** Reading phone lock... OK Phone lock: 00000000 Reading SIM lock... OK SIM lock: 00000000 Done with Samsung Tool v.19.0 Done with Samsung Tool v.19.0 BUT SIM CODE ERROR |
