Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 07-30-2008, 22:29   #1 (permalink)
Member: 619511
j400 unlock problem
i need help how to unlock j400 and it driver
Old 07-30-2008, 22:44   #2 (permalink)
Member: 55654
take a look on HowToUnlock section.
Regards!
Old 07-30-2008, 23:57   #3 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
yes follow Instructions Post # 2
or don't connect USB part cable to pc, you need to connect only Rj part
use only FTD, no need drivers etc.
Old 07-31-2008, 00:59   #4 (permalink)
Member: 619511
i tried it but error like this
Connecting to phone... (Press Power ON for a short time)
ERROR - Can't connect to phone! [ERR#02]
Old 07-31-2008, 04:03   #5 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
its Communication error ,
you need to check
Cable, Phone Jack, FTDI Port Setting, or please check also phone battery is Charge (need only 20% charged)
Old 07-31-2008, 05:02   #6 (permalink)
Member: 619511
i have chack cable and phone jack are ok, how will i set FTDI Port Setting
thanks
Old 07-31-2008, 21:44   #7 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
connect your box and install all drivers
go to Device manager --> port setting and check No. Comport if you see Example Com 4
so you need to select under the EUBOX software Com4
Old 07-31-2008, 21:53   #8 (permalink)
Member: 180091
I HAVE SAME PROBLEM WITH j750. WHEN YOU SAID THAT PHONE MUST BE ON WITHOUT SIM, WHY SHOULD WE NEED TO PRESS POWER ON AGAIN AS SAID IN POST 2? HOW CAN THIS PROBLEM BE SOLVED? THANKS
ADEBAM.
Old 07-31-2008, 22:22   #9 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
this kind of phone get bad comunication sometimes. j750, j400 but u have to try three of four times...finally always is unlocked, but have to be perseverant.
i faced this poblem too with these mobiles, but always finish by unlocking with EU.
Still don t understand where is problem from coz some of them go on first try and others have to try 4 or 5 times.
same pc, same cable, same ftdi....
just try and u 'll unlock
BR,
Old 08-01-2008, 02:21   #10 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
ok Brother Please Follow this Instructions
HOW TO UNLOCK
  • RUN Samsung 3G Easy Unlocker v1.60
  • Select Broadcom mode
  • Connect Cable ONLY E210 RJ45 (E210 combo cable but only RJ part use not connect usb part of cable)
  • Phone Must be off
  • PORT SETTING: Select your box FTDI port No.
  • Click Start
after few Second your phone will be Unlocked
Please Take a look this screen shot (it will help you)
Don't Forget Post Report
Old 08-01-2008, 11:23   #11 (permalink)
Member: 180091
still same problem
i still encountered same problem while trying to unlock J750 after following your instruction step by step. can give a video of how to unlock this phone maybe it will be better, or is there any trick as we have in A717 by setting connection on the phone for it to be recognised. quick response is needed before returning the phone to customer, or before i give someone that uses NSpro.
Old 08-01-2008, 11:29   #12 (permalink)
Member: 180091
[IMG]C:\Documents and Settings\adeyemo bamidele lia\My Documents\My Pictures\untitled[/IMG]
Old 08-01-2008, 11:36   #13 (permalink)
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Use the direct unlocker software latest version 1.60 just use pluggin the RJ45 connector NOT USB CONNECTOR
regards !
Old 08-02-2008, 07:49   #14 (permalink)
Member: 619511
still the same problem
Old 08-02-2008, 08:02   #15 (permalink)
chahin's Avatar
Member: 778985
I had the same problem with j 750
but when i changed my e210 cable it's solved
try with an other e 210 cable.
j400 unlock problem sesime NSPRO 8 12-01-2009 05:02
J400 unlock problem ..::GsmHelp::.. UST Pro II 1 12-29-2008 02:33
J400 unlock problem Burnt Cobba NSPRO 5 07-08-2008 19:30
J400 unlocking problem tomaszwl Easy-Unlocker 9 04-01-2008 13:50
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 0.49073 seconds with 11 queries
