Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 05-31-2008, 18:17   #1 (permalink)
wiliam's Avatar
Member: 241831
Thanks Meter: 18
No Server No Server Server Off Pls Check
Phone info:
Phone Model: A737
Revision: A737UCGI3
IMEI: 359673012140449
SIM lock password: 0000
ERROR - Can't connect to server!
Check your internet connection or try again later...
Old 05-31-2008, 19:01   #2 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
I have the same problem.
Phone info:
Phone Model: A707
Revision: A707UCGD2
IMEI: 355458015908180
Phone lock password: 5650
Old 05-31-2008, 19:30   #3 (permalink)
Member: 21296
Thanks Meter: 328
I finished the phone using Direct Unlock function, you can try that also. Procedure here: Post Only Successfully Unlock with Screenshot & Instructions
Old 05-31-2008, 21:05   #4 (permalink)
yueyo's Avatar
Member: 38307
Thanks Meter: 66
Just use "Samsung 3G Easy Unlocker.exe" instead of "Samsung 3G Easy Unlocker Online Code Reader.exe"
Old 06-01-2008, 06:54   #5 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,297
Phone info:
Phone Model: A707
Revision: A707UCGD2
yes if server down or doing some problem then you can use direct unlocker
Old 06-01-2008, 09:36   #6 (permalink)
Member: 56735
Thanks Meter: 34
yes i'm ok with u but what's solution to get licence because i have formated my PC im confused with my customers
Old 06-01-2008, 11:48   #7 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,656
answer:
Problem getting signatures...
Old 06-01-2008, 12:32   #8 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,009
what about phones without direct unlock procedure
Phone info:
Phone Model: OT-C701/C701A
Revision: Alcatel 010 03
IMEI: 3532050171*****
Manufacturer: Alcatel
if we have tool and we are not sure to be able to unlock phone so little interesting tool if can t use it
plz solve that problem or make direct unlock for other models.
Old 06-01-2008, 12:39   #9 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,297
Originally Posted by .::Ja\/\/aD::. View Post
no need to check antivirus or firewall, its understood that server down, all members have same problem is members have antivirus or firewall problem?, you are product supporter and never missguide your members, be genious
Old 06-01-2008, 12:45   #10 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,009
oooh, this is really a problem if u don t have a copy of files and no server...
rahet 120mille ya kho...
try to have always a copy of licence files and setup in a cd for cases like this
Old 06-01-2008, 12:59   #11 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
always copy your all *.lic files from C:\Program Files\EasyUnlockerBox to safe place (cd/dvd/inbox)
Old 06-02-2008, 07:59   #12 (permalink)
wiliam's Avatar
Member: 241831
Thanks Meter: 18
thx mate problem solved by your method
Old 06-02-2008, 10:31   #13 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,297
Atleast Server OK Today
http:///vbb/showthread.php?t=545707
Old 06-02-2008, 10:39   #14 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,899
Today ok
Phone info:
Phone Model: L760
Revision: L760BUGH1
IMEI: 3566030********
Connected to server
Unlock codes:
UNLOCK NETWORK LOCK: #7465625*638*15853840#
Enter codes WITHOUT simcard inside the phone.
You can check the current lock status using this code: *#7465625#
Old 06-02-2008, 10:50   #15 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,297
Thanx for sharing, always post here with screenshots
http:///vbb/showthread.php?t=541778
cant connect to server....pls. check FMC_GSM Smart-Clip 1 01-14-2010 08:21
server off please check nzeiga FuriousGold 1 06-29-2009 08:49
pls check the server:Connecting to server... TALIAT FuriousGold 2 01-31-2009 14:52
M50 goes off when check the capacity in messeges menu doberman E-Gold Based Phones 4 03-05-2003 16:48
Page generated in 0.44258 seconds with 8 queries
