Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 06-27-2011, 10:50   #16 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 579
C3300K direct unlock ok within 6 seconds...
Booting phone in testmode
11:48:06 AM - TAT Mode: Done
11:48:06 AM - Analysing Data..
11:48:08 AM - Model: C3300KXXJH3 (August 2010)
11:48:08 AM - Imei: 35656004074067
11:48:08 AM - MSL Address: RUVB527294
11:48:08 AM - Sending Data to Server...
11:48:13 AM - Unlocking...
11:48:15 AM - Unlock Done !...
If phone asks for code enter 00000000
-- Operation done in 24 seconds --
The Following User Says Thank You to Unlocker AL For This Useful Post:
Old 06-27-2011, 15:53   #17 (permalink)
Member: 1589799
Sonork: raj
i have z3x box but i can not unlock i5500b and s3350 samsung 3g tool 9.4 version i need android driver i think usb driver for samsung modem and i5500 so please some help me please.............
Old 06-27-2011, 16:50   #18 (permalink)
dzunlocker's Avatar
Member: 79640
Sonork: 1577251
Thanks Meter: 238
This is EUB support section.
Ask help on Z3X support section.
Regards
Old 06-28-2011, 09:01   #19 (permalink)
Bigbrothers2000's Avatar
Member: 487
Thanks Meter: 65
9:55:39 - Booting Phone
9:55:41 - Getting Data from phone
9:55:42 - Firmware: M7600BVIE
9:55:42 - Imei: 35282603156514
9:55:42 - UniqueNumber: 80370000127613
9:55:42 - Sysinfo Location: 1010 Reading..OK
9:55:44 - Decrypting Codes..
- Unfreeze: 24075139 + OK
- Unlock Network: #7465625*638*51837259#
- Unlock SP Lock: #7465625*77*00000000#
- Unlock Sub Lock: #7465625*782*00000000#
To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key
To unlock: REMOVE simcard from phone and type the full unlock codes.
-- Operation done in 13 seconds -- Detected COM34 - STATUS: Ready (COM)
Remark: Sometimes the modemport is not detected correctly, then you have to set this port manually
Old 06-28-2011, 16:18   #20 (permalink)
ashvin's Avatar
Member: 106700
Thanks Meter: 47
Sysol Download Mode: Done
7:12:30 AM - Sending Preloader...
7:12:31 AM - FLASH ID: 0008 [K5N5629ATA_TOP]
7:12:31 AM - Switching Portspeed.
7:12:32 AM - Sending mainloader...
7:13:00 AM - Reading E2P please wait.. 127/127
7:14:37 AM - Analysing eprom structure...
7:14:41 AM - FIRMWARE: C3500XXKB2 (February 2011)
7:14:41 AM - IMEI: 35402804077695F
Unlock Code1 Found: 17984720
Master Unfreeze: 54459910
7:14:42 AM - Operation: Done
-- Operation done in 137 seconds --
Old 06-28-2011, 22:27   #21 (permalink)
Member: 1025102
Thanks Meter: 74
unlock samsung L870 Eu-Box ok
Connecting to Phone...
13:16:38 Phone Model:SGH-L870
13:16:38 - Firmware: L870BAHJ3
13:16:38 - Uniquekey:70570
13:16:40 - IMEI:354
13:16:41 - MSL Address:R4YQB95221
13:16:41 - Bruteforcing infineon MSL
17:51:04 - Sending data to server
17:51:06 - MSL bypass:568154
17:51:06 - Unlocking Phone
17:51:07 - Rebooting phone
17:51:08 - Operation: Done
-- Operation done in 16473 seconds --
Old 06-29-2011, 00:48   #22 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 160
a question ..... the easy with this module supports the Samsung A187, A167 and A107?
Old 06-29-2011, 09:58   #23 (permalink)
drnele's Avatar
Member: 19493
Sonork: 100.1596420
Thanks Meter: 185
I9100 unlock few seconds
Here is it...........
b.r.
The Following User Says Thank You to drnele For This Useful Post:
Old 06-30-2011, 16:42   #24 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
S8500 unlocked !!
17:39:50 - Booting Phone
17:39:52 - Getting Data from phone
17:39:52 - Firmware: S8500XXJID
17:39:52 - Imei: 354627040xxxxx
17:39:52 - MSL Serial: RUTZ806032
17:39:53 - UniqueNumber: 86070000463789
17:39:53 - Sysinfo Location: BA11 Reading..OK
17:39:54 - Decrypting Codes..
- Unfreeze: 83958263 + OK
- Unlock Network: #7465625*638*17935385#
-- Operation done in 8 seconds --
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 07-01-2011, 12:41   #25 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
e2550 unlock done !
11:39:52 - TAT Mode: Done
11:39:52 - Analysing Data.. (EFLGBBC)
11:40:00 - Model: E2550DBGJI1 (September 2010)
11:40:00 - Imei: 35517004510805
11:40:01 - MSL Address: RPOZB04292
11:40:01 - Sending Data to Server...
11:40:01 - MSLCODE not found, checking server for alternative.
11:40:03 - Extended bypass activated, Start Unlocking...
11:40:05 - Unlock Done !...
Old 07-01-2011, 15:37   #26 (permalink)
J3soft's Avatar
Member: 448639
Thanks Meter: 165
model x486 unlocked for new soft
Booting Trident Phone...
09:28:16 a.m. - Set testmode: Done
09:28:16 a.m. - IMEI: 3321856???????
09:28:17 a.m. - Phonecode:0000000
09:28:18 a.m. - Simlock Status:ACTIVE
09:28:18 a.m. - Provider ID:aleaE
- Unlock Network: #0111*10579387#
- Unlock Sub Lock: #0121*10579387#
- Unlock SP Lock: #0133*10579387#
- Unlock Sim Lock: #0141*00000000#
- UnFreeze: #0199*80280590#
09:28:25 a.m. - Code reading: Done
You can now type in the above code(s) in phone.
-- Operation done in 15 seconds --
Old 07-01-2011, 15:45   #27 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
J700 unlocked !! !!
16:44:44 - TAT Mode: Done - Analysing Data..
16:44:48 - Firmware: J700BRHA4 (January 2008)
16:44:48 - Imei: 359913011xxxxx
16:44:49 - MSL Address: R3XQ256114 Sending to Server...
16:44:50 - MSL Bypass Code: 934725
16:44:50 - Decrypting UnlockCodes...
- Unfreeze: 50664170 + OK
- Unlock Network: #7465625*638*80001450#
- Unlock SubLock: #7465625*782*00000000#
- Unlock Simlock: #7465625*746*00000000#
- Phonecode: 00011111
-- Operation done in 14 seconds --
Old 07-01-2011, 20:17   #28 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
s5830
Setting testmode.
19:14:52 - OMAP Testmode: Done
19:14:52 - Reading Phonedata
19:14:52 - Firmware: S5830BGKC1 (March 2011)
19:14:52 - Imei: 35749604603460
19:14:52 - Chipset: M76XX-TSNCJOLYM-6050
19:14:52 - MSL Addr: RFEB492838
19:14:52 - Getting Bypass Code from server
19:14:53 - Not in database, Starting Security Analysis...
19:15:52 - EntryPoint found, Updating Database
19:15:53 - AKSEED: 10441-13-55 Auth: 1279-91-94
19:15:53 - Unlocking...
19:15:53 - Leaving Testmode
19:15:54 - Unlock Done...
If phone asks for a code enter 00000000
-- Operation done in 64 seconds --
Old 07-01-2011, 21:04   #29 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
s5670 android
Setting testmode.
20:02:23 - OMAP Testmode: Done
20:02:23 - Reading Phonedata
20:02:23 - Firmware: S5670JXKA4 (January 2011)
20:02:23 - Imei: 35633004150385
20:02:23 - Chipset: M76XX-TSNCJOLYM-6050
20:02:23 - MSL Addr: RP7B406709
20:02:23 - Getting Bypass Code from server
20:02:24 - Not in database, Starting Security Analysis...
20:03:23 - EntryPoint found, Updating Database
20:03:24 - AKSEED: 10441-13-55 Auth: 1279-91-94
20:03:24 - Unlocking...
20:03:28 - Leaving Testmode
20:03:28 - Unlock Done...
-- Operation done in 68 seconds --
Old 07-02-2011, 11:57   #30 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
i6410 unlock done
Setting testmode..
10:55:41 - OMAP Testmode: Done
10:55:41 - Reading Phonedata
10:55:41 - Firmware: I6410BUJA2 (January 2010)
10:55:41 - Imei: 35571703017166
10:55:41 - Chipset: M6246A-KPRZL-1.2.0035_7S
10:55:41 - MSL Addr: S200015531
10:55:41 - Getting Bypass Code from server
10:55:42 - AKSEED: 10441-13-55 Auth: 1279-91-94
10:55:43 - Unlocking...
10:55:47 - Leaving Testmode
10:55:47 - Unlock Done...
-- Operation done in 10 seconds --
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.25524 seconds with 10 queries
