Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 10-02-2009, 06:57   #1 (permalink)
Member: 771272
Problem to unlock samsung s5233s!!!!! please advive
Hi!
I got a premium account to day and try to unlock Samsung s5233s.
I used combo cable USB/ rj45 to connect , however every time i connect COMBO CABLE OF usb to pc, computer CANNOT RECOGNIZE THE PHONE, THAT MEANT PORT2 : CAN NOT BE A SAMSUNG MODEM.
However, if i only use original samsung usb cable and connect phone to pc, Computer can detect the phone as samsung modem. But in this case I can not unlock phone because it only 1 port only.
Please advice, I think software not detect this phone.
thank you
tommy
Old 10-02-2009, 11:58   #2 (permalink)
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Please, send me screenshot with your port list to info@easy-unlocker.net also connected with original cable, send me both pictures.
BR.
Old 10-02-2009, 12:42   #3 (permalink)
Member: 137474
Sonork: 100.109924
Originally Posted by tommyvo View Post
Hi!
thank you
tommy
Then like you see you got foulty cable 2in1 just use good one working and all will work ok. bye
Old 10-03-2009, 01:58   #4 (permalink)
Member: 771272
hi!
I wonder if combo cable e210 is working on samsung s5233s or not?
The reason is I got this cable come with box, everytime i connect phone( samsung s5233s) to pc throught usb. Phone not charging and PC DO NOT detect phone at all.
However, with same that cable , I connect to another samsung phone, It is charging phone and computer detect phone very well.
That is meant cable combo E210 come with box is not working for samsung s5233s.
Supporter, please let me know which cable I should use for this samsung s5233s? Could you please advice any good cable to work on samsung s5233s?
Thanks
Tommy
thank you
Old 10-03-2009, 10:58   #5 (permalink)
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Friend, working cable is Samsung E210 Combo cable...
Old 10-07-2009, 03:25   #6 (permalink)
Member: 771272
Anybody help me........It not working to unlock SAMSUNG S5233s.....I spent 100eu to get premium account to unlock this phone and now IT NOT WORKING.
Please help me....
Thank you
Old 10-09-2009, 01:40   #7 (permalink)
Member: 606801
same problem tommyvo, ok with usb on computer but not detected with combo cable i tried with 3 different combo cable thanks to help us AEROM
HELP HELP HELP
Old 10-09-2009, 02:26   #8 (permalink)
BouRRi_GSM's Avatar
Member: 111457
COMBO cable existing in the market will not connect with Samsung infineon and Brodacom with USB.
cause those cable have Charge pins (19+20) connected to +5V_USB pin (18), and this don't cause any problem with Qualcomm but cause this problem with infineon and broadcom.
u can open ur cable and remove Charge pin from ur COMBO cable.
br
Old 10-09-2009, 07:01   #9 (permalink)
Member: 771272
Thanks for that!
I do not know how to modify combo cable.
Do you know any reseller that sell combo cable be able to unlock samsung s5233 throught EU box.
Or we will never can unlock this phone with combo cable come with box...bad luck.....
thank you
Old 06-23-2012, 14:20   #10 (permalink)
Member: 1359160
Sonork: 654280
Samsung s5233s problem with hwk
connect phone to RJ-45 Without Battery ! ExtBL Failed:no BOOT Signal UART_BOOT Done File: \S5233S\BOOT FILES\bcmboot.imgS5230-img START:00000000 SIZE:0000D720 TX_START Failed:0,69 NAND Write Failed
help sir
Old 06-23-2012, 15:04   #11 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Post in right section, you won't get any answer in here
Old 06-23-2012, 15:55   #12 (permalink)
Member: 216705
a have no idea about this kind of phone but i think it the same as gt s3650 ..
dump or back up firmware for back up
try to debrand the mobile
and try unlock it again
if you have problem in detecting it try hold volume - key or volume - key and plug it computer and insert battery
Problem to Unlock Samsung I450. I enter code OK, but Not Unlock [SOLVED] Grupo MovilFree PolarBox 2 2 03-11-2010 11:15
problem to unlock Samsung s5233s!!!! Please advice solution tommyvo UST Pro II 5 10-08-2009 12:51
Problem to Unlock Samsung E250v.Canīt see codes and unlock directly ::: SOLVED ::: Grupo MovilFree PolarBox 2 9 09-06-2009 14:37
Need code to unlock samsung F210 please kourosh10 Phone Unlocking Codes & Maps 1 02-10-2009 17:55
How to unlock Samsung Z230 PLEASE johnreza QUALCOMM Models (3G) 12 01-30-2009 19:33
Page generated in 0.32821 seconds with 11 queries
