Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 02-28-2009, 23:33   #1 (permalink)
Member: 642622
Problems with com ports on eu box
I am trying to unlock samsung A707 with the EU box using the 3G online code reader. Port 1 should be samsung CDMA modem and 2 should be the usb serial port. I could only get these port options.
COM1 (communications port)
COM4(Lucent Win Modem)
COM6(sphere GSM Fighter cable)
LPT1(ECP Printer Port)
When I tried with these ports I got the error message:
Can't get CRYPTKEY
Old 02-28-2009, 23:47   #2 (permalink)
aErOm's Avatar
Member: 7900
Sonork: 100.78126
Thanks Meter: 4,990
in PORT 2 you must select the port where you have BOX CONNECTED, when you connect box to PC it creates COM VIRTUAL PORT based in the USB port, sometimes you use FIGHTER DRIVERS to recognize box, other times you get something like USB <-> COM or if you correct installed box with correct drivers just get a COM PORT NUMBER, check where is your case, that based in your words seems to be the SPHERE GSM FIGHTER CABLE and do jobs ....
Is very easy, donīt worry.
With my best wishes.
The Following User Says Thank You to aErOm For This Useful Post:
Old 03-09-2009, 12:26   #3 (permalink)
Member: 642622
Thanks for your help, how do you use the drivers to recognise the box? Thanks again.
Old 03-10-2009, 11:35   #4 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,640
When it ask for Drivers, choose "Install the software Automatically" if there is compatible drivers, if it doesnt found, choose "install from a list or specific location". then browse the driver. And install "Samsung_USB_Driver_Installer". before unlock
The Following User Says Thank You to xerraco For This Useful Post:
Old 04-10-2009, 02:25   #5 (permalink)
Member: 642622
Finally I got my EU box to work. However, I now have problem with opening the software. I kept getting the message you need the license to activate. I have activated the remote client and got license but I still get the same message. Can anybody please help?
Old 04-11-2009, 01:48   #6 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,656
you mean still you're face error "Can't get CRYPTKE" if i am right Please check few thinks
i'm sure you're select wrong comport setting
Like
Please Select Right Com ports
Like
i hope after Right Com Port Selection your's Problem will be Solve if after that not solve
Kindly post here Screen Shot (software) then we'll help you how you unlock correctly
Thanks very much
Old 04-18-2009, 09:58   #7 (permalink)
Member: 642622
I still have problem getting the right com port- Samsung CDMA modem.
I have tried to install the samsung usb driver where there are 3 files:
samsung CDMA madem
sansung mobile usb modem
samsung pc studio which has 3 files-usb drivers- 1, 2. 3
Which of these do I need to install to unlock samsung A707?
Old 04-18-2009, 13:39   #8 (permalink)
Member: 180091
Thanks Meter: 59
@Ayindeokin
try to see me in my office if you're in Ibadan. You need a little training on this which might not be tottaly solved here with your level of understanding. Wa ri mi ki nso nto ma se.
Adebam
Old 04-22-2009, 00:51   #9 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
you need to install samsung CDMA modem
PS: i am agree with adebam please try to read Post/Threads/manuals/ about how to use, how to unlock bla bla
Old 04-24-2009, 00:48   #10 (permalink)
Member: 642622
problem with com ports on EU
Hello,
i have installed the cdma samsung driver but it did not come up on the com port. however, the micrsoft scanner and camera started up.Thanks.
ayindeokin
Old 04-24-2009, 14:15   #11 (permalink)
.::LUQMAN::.'s Avatar
Member: 413053
Sonork: 100.114351
Thanks Meter: 457
All Reday Post On Fouram Read FAQ & Search
Old 04-25-2009, 13:39   #12 (permalink)
Member: 642622
problems with com ports on EU
I have had this problem for some time and have searched for threads.I have not seen one that solve my problem. If you seen the thread, you can show me the thread I will appreciate it.
Ayindeokin
Problem with com ports iliya _angelov Easy-Unlocker 1 02-26-2009 08:15
problem with com ports vladmoto SETool2 4 06-27-2007 11:50
problem with com ports vladmoto SETool2 0 06-27-2007 09:41
problem with com ports vladmoto SETool2 0 06-27-2007 09:09
Ub Problem With Com Port 1 francogsm Universalbox 0 09-25-2006 20:53
Page generated in 0.34519 seconds with 8 queries
