Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 08-19-2009, 09:12   #1 (permalink)
hoangtruongson's Avatar
Member: 392170
Sonork: 1587688
Thanks Meter: 150
How to unlock Samsung T749
Phone info:
Phone Model: T749
Revision: T749UVIF3
IMEI: 3524940304****
Phone lock password: 00000000
SIM lock password: 00000000
Reading data from phone...
ERROR - Can't read simlock data!
thanks advice
Old 08-19-2009, 17:51   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
which software version you're use for unlock this phone ?
please try to use latest software version or i think it is not supported phone for unlock
Old 08-22-2009, 19:44   #3 (permalink)
haiminhk15_sc's Avatar
Member: 152057
Sonork: 100.1582385
Thanks Meter: 220
I'm also tested it by read code tool with something CPU type. But not successfully
Old 11-16-2010, 15:14   #4 (permalink)
Member: 204802
Successfully unlocked with Z3X
Put phone in qualcomm mode the same procedure of T919
Qualcom mode method (only usb):
1. Power on phone.
2. Type *#197328640# -> common -> usb config -> Qualcomm mode
3. Connect USB part of 2in1 cable, setup drivers.
4. Choise qualcomm diagnostic port in port settings.
5. Choise unlock method: Read codes or Direct.
6. Press Unlock SP button.
Samsung mode method (2in1 cable):
1. Power on phone.
2. Type *#197328640# -> common -> usb config -> Samsung mode
3. Connect 2in1 cable, setup drivers.
4. Choise port of RJ45 connector in port settings
Log:
Model: SGH-T749
CountryCode: TMB
Factory SW: UVIK1
UniqueNumber: 55690000******
MemoryPhone: K5R2G1GACC(T749)S
IMEI: 359225030*****/*
Phone S/N: RPESC08974
Build: SBAM6290A-KPVZL-1.2.0080_1U
Reading SysInfo... error (Cant read Security data)
Searching SysInfo... OK
Reading SysInfo... OK
Calculating codes... OK (time - 00:00:49)
Freeze code: 80830485
NET lock: #7465625*638*90358509#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
Done with Samsung 3G tool ver 8.6
Best Regards,
Old 08-04-2015, 09:56   #5 (permalink)
Member: 963505
Thanks Meter: 50
[QUOTE=hoangtruongson;4762399]Phone info:
Phone Model: T749
Revision: T749UVIF3
seam problem how to unlock kindly help me
Selected port: COM39 Z3X BOX Serial Port
Selected port speed: 115200
Searching Samsung modem... detected COM23
Reading phone info...
Model: SGH-T749
Phone version: T749UVIK1
IMEI: 35257304216****
Reading phone lock... OK
Phone lock: 00000000
Reading SIM lock... OK
SIM lock: 00000000
Done with Samsung Tool v.19.0
BUT SIM CODE ERROR
How to unlock Samsung E900 ? Direct Unlock dont work MisterX GSMFREE HWK 6 08-03-2010 17:31
how to unlock samsung t749 ruvanw1979 UST Pro II 0 03-05-2010 11:02
how to unlock samsung t749 T mobile ? who_i UST Pro II 2 02-02-2010 19:59
How to unlock samsung T749 hoangtruongson Z3X-Team Products 2 09-13-2009 05:12
how to unlock samsung A727 and what cable to use?? tsarkh Rocker Dongle (By Legija) 6 07-02-2008 19:59
Page generated in 0.16910 seconds with 9 queries
