Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 07-04-2008, 19:18   #1 (permalink)
msa
Member: 17424
Thanks Meter: 15
U900 still locked after direct unlock
Hi
I unlocked U900 by direct unlock, software says phone unlocked but phone still says network locked. Used direct unlock while server was down .
Phone info:
Phone Model: U900
Revision: U900BOHD
IMEI: 3524420****757*
OK - Phone unlocked
Now for Good news Unlocked same phone with code reader
Phone info:
Phone Model: U900
Revision: U900BOHD
Phone lock password: 00000000
SIM lock password: 00000000
Your phone doesnt seems to be manufactured by Samsung.
We cannot guarantee that any given unlock codes will be correct.
Connected to server
Unlock codes:
UNLOCK NETWORK LOCK: #7465625*638*418****7#
Enter codes WITHOUT simcard inside the phone.
You can check the current lock status using this code: *#7465625#
Disconnected from server
PS. I have unzipped the new shell files into existing installed directory, but none of the software files open. I noticed the file names in the db.ini has been changed, so I changed the software file names to match what it says in db.ini , now when I click on 'Load' the message comes up saying 'This button will run the software ' but still it does not load the file .
not sure what else need to modify.
br
msa
br
msa
Old 07-05-2008, 02:00   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
be patience, we are work on it,
u880 still lock after flasing unlock file dsakun899 ULT PRO 0 01-26-2008 22:15
k510i Still Locked after 3 unlock attempts mishaelwillo Cruiser Suite 8 10-18-2007 08:37
myC4-2 still locked with direct unlock.... ZIYAAD STRYKER ARM9 BASED M62 / M62+ 3 06-29-2007 19:09
U8330I still locked after direct unlock. ?? TRABEL LG 3G (USB-Smart) 27 07-13-2006 10:56
Sagem 920 still locked after valid unlock code. GSM_Kraker Infineon C16X M51 & ARM7 M52 BASED 0 10-27-2000 14:16
Page generated in 0.16027 seconds with 9 queries
