03-01-2009, 00:33 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 642622 Status: Offline Thanks Meter: 0 | Problems with com ports on eu box COM1 (communications port) COM4(Lucent Win Modem) COM6(sphere GSM Fighter cable) LPT1(ECP Printer Port) When I tried with these ports I got the error message: Can't get CRYPTKEY |
03-01-2009, 00:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Any Beautiful Place Age: 45
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | in PORT 2 you must select the port where you have BOX CONNECTED, when you connect box to PC it creates COM VIRTUAL PORT based in the USB port, sometimes you use FIGHTER DRIVERS to recognize box, other times you get something like USB <-> COM or if you correct installed box with correct drivers just get a COM PORT NUMBER, check where is your case, that based in your words seems to be the SPHERE GSM FIGHTER CABLE and do jobs .... Is very easy, donīt worry. With my best wishes. |
The Following User Says Thank You to aErOm For This Useful Post: |
03-10-2009, 11:35 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | When it ask for Drivers, choose "Install the software Automatically" if there is compatible drivers, if it doesnt found, choose "install from a list or specific location". then browse the driver. And install "Samsung_USB_Driver_Installer". before unlock |
The Following User Says Thank You to xerraco For This Useful Post: |
04-10-2009, 02:25 | #5 (permalink) |
Member: 642622 Status: Offline Thanks Meter: 0 | Finally I got my EU box to work. However, I now have problem with opening the software. I kept getting the message you need the license to activate. I have activated the remote client and got license but I still get the same message. Can anybody please help? |
04-11-2009, 01:48 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | you mean still you're face error "Can't get CRYPTKE" if i am right Please check few thinks i'm sure you're select wrong comport setting Like Please Select Right Com ports Like i hope after Right Com Port Selection your's Problem will be Solve if after that not solve Kindly post here Screen Shot (software) then we'll help you how you unlock correctly Thanks very much |
04-18-2009, 09:58 | #7 (permalink) |
Member: 642622 Status: Offline Thanks Meter: 0 | Problems with com ports on eu I still have problem getting the right com port- Samsung CDMA modem. I have tried to install the samsung usb driver where there are 3 files: samsung CDMA madem sansung mobile usb modem samsung pc studio which has 3 files-usb drivers- 1, 2. 3 Which of these do I need to install to unlock samsung A707? |
04-18-2009, 13:39 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | @Ayindeokin try to see me in my office if you're in Ibadan. You need a little training on this which might not be tottaly solved here with your level of understanding. Wa ri mi ki nso nto ma se. Adebam |
04-22-2009, 00:51 | #9 (permalink) |
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | you need to install samsung CDMA modem PS: i am agree with adebam please try to read Post/Threads/manuals/ about how to use, how to unlock bla bla |
04-24-2009, 00:48 | #10 (permalink) |
Member: 642622 Status: Offline Thanks Meter: 0 | problem with com ports on EU Hello, i have installed the cdma samsung driver but it did not come up on the com port. however, the micrsoft scanner and camera started up.Thanks. ayindeokin |
04-25-2009, 13:39 | #12 (permalink) |
Member: 642622 Status: Offline Thanks Meter: 0 | problems with com ports on EU I have had this problem for some time and have searched for threads.I have not seen one that solve my problem. If you seen the thread, you can show me the thread I will appreciate it. Ayindeokin |
Problem with com ports | iliya _angelov | Easy-Unlocker | 1 | 02-26-2009 09:15 |
problem with com ports | vladmoto | SETool2 | 4 | 06-27-2007 11:50 |
problem with com ports | vladmoto | SETool2 | 0 | 06-27-2007 09:41 |
problem with com ports | vladmoto | SETool2 | 0 | 06-27-2007 09:09 |
Ub Problem With Com Port 1 | francogsm | Universalbox | 0 | 09-25-2006 20:53 |
