Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 01-09-2007, 19:23   #1 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
Zv40
hello
i've tryed to unlock ZV40 but always same error installed drivers correctly modem com port ok with sim and without sim inside removed all modem reinstalled drivers restarted computer tryed on one desktop and on laptop but the same pls how to solve problem
thank's
Old 01-09-2007, 20:32   #2 (permalink)
Member: 55654
Thanks Meter: 9
Hi,
Should be works ok! Do you have other cable for test ?
Test that the sim inside of the phone is blocked for this phone.
Try and post results!
Regards.
Old 01-09-2007, 20:37   #3 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
problem solved using flash mode
thank's
Old 01-09-2007, 21:06   #4 (permalink)
Member: 55654
Thanks Meter: 9
Perfect!
Regards!
Old 01-20-2007, 15:03   #5 (permalink)
Member: 12242
Thanks Meter: 11
can you tell more plz, because normally it should work in normal mode, on your screen you had selected Z540 ?
regards,
Old 01-20-2007, 20:42   #6 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
yes put the zv40 on flash mode ''9+power'' the choose flash mode Z540 choose the com modem of your samsung the do start that's all
ZV40 only "DOWNLOAD ZV40 USB_FE3a" F@RUK S UST Pro II 3 01-24-2009 21:37
Can Ust pro 2 unlock Zv40 trainmaniac UST Pro II 8 12-08-2006 22:07
ZV40 unlock Braen QUALCOMM Models (3G) 3 10-22-2006 05:32
zv40 unlocking not working Roughrider202 NSPRO 2 08-05-2006 12:21
ZV40 unlocking? 8210 NSPRO 1 08-01-2006 11:56
Page generated in 0.18203 seconds with 10 queries
