HOW TO FULL REPAIR DEAD/EROR on you motorola BY UBL 100% 2 Attachment(s) >> HOW TO FULL REPAIR DEAD/EROR on you motorola BY UBL 100% << STEP 1 : without TEST POINT MAKE BATTERY FULL CHARGED Entrer phone on FLash MODE by pressing #+*+power on (it is not nessessary if phone not power on , maybe this is in BLANK MODE...) SELECT MODEL do ENTER BLANK then REPAIR then LEAVE BLINK (mike picture attached 1) STEP 2 : with TEST POINT if first STEP not solve problem here is final and FULL SOLUTION to FULL REPAIR your motorola at 100 % do TEST POINT select MODEL check connect over TP do REPAIR and after FLASH with 1FF File (avalaible on your DVD) (like picture attched 2) SO THAT IS SO EASY enjoy UBL the BEST:D :D :D |
thanks for sharing mate!!! |
Thanks for the info BUT NOT ALL CAN FIX THIS PROBLEM SPECIALLY NEW FIRMWARE VERSION on the PHONE. RSD LITE can HELP SOME MOTOROLA PHONE specially in FLASHING, 100%. FOR ME, the best METHOD TO UNLOCK MOTOROLA PHONE using UBL is to USE TESTPOINT, 100% TRIED, TESTED & PROVEN without PROBLEM. br RNC_EBM |
thanks for sharing................ |
i know that ... and you have reason ... the best is to using TP but dont know that we love UBL because it include SKIP TP:D :D :D |
how to unlock l7 or l6 |
i too agree wth u..'skip tp'option s so cool..ubl works soo good for allmost all p2k series,weras its still having probz n odm series |
FOR OTHER INFO / SOLUTION for L7 & V360 : L7 BootLoader 9.0.2 = V360 BootLoader 9.0.2 for L7 = Compatible firmware VERSION to FLASH = R4513_G_08.B7.DCR or HIGHER for V360 = Compatible firmware VERSION to FLASH = R4513_G_08.B7.E0R or HIGHER Tried, Tested and Proven 100% Working. br RNC_EBM |
@RNC_EBM THX MAN FOR YOUR COORPORATION ... very nice info and work:D :D :D |
thanks all fo this inforation work fine with tp |
Thanks mate I revive my v975 using this solution. I tried unlocking v975 using without TP with UBL but I accidentally press unlock button and give error OxDAB.. I tried repairing PDS using smart-clip but not succeed, so i turn to UBL using this procedure.. after repair I flash again the unit using smart-clip and it works... note: i didnt used UBL flash file coz i dont still copied from the dvd's. |
>>> RSD LITE 3.5 & P2K Driver 2.9 <<< |
Very usefull thread, thank you for this, now is sticky. Best Regards, Manole |
Thanks for making it sticky. br RNC_EBM |
