Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultima Box Light
Old 07-18-2007, 14:41   #1 (permalink)
Member: 103342
Thanks Meter: 6
Motorola C121 unlock help help
Motorola C121 unlock errorrr help help
Motorocker_217
Phone should be powered OFF
Open serial interface COM8
Please press and HOLD power ON button
Error: 40010201
Error: 40100103
Old 07-18-2007, 14:42   #2 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
Phone is not connected, which cable did you use ?
Old 07-19-2007, 07:56   #3 (permalink)
Member: 103342
Thanks Meter: 6
1-Ufs
2-Com data cable
3-Motorola odm cable
ISN'T SEEING SAME
Old 07-19-2007, 08:06   #4 (permalink)
Member: 103342
Thanks Meter: 6
Motorocker_217
Error: 40010201
Error: 40100103
1-Ufs
2-Com data cable
ISN'T SEEING SAME
Old 07-21-2007, 07:15   #5 (permalink)
Member: 194607
Thanks Meter: 34
use t191 com cabel and use com 1
Old 07-21-2007, 09:32   #6 (permalink)
Member: 103342
Thanks Meter: 6
Same
no connedted
Old 07-21-2007, 10:22   #7 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
Dissasembly the phone to be sure that cable is properly inserted.
Old 07-21-2007, 22:39   #8 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
Hi
I use a T191 ufs cable with directcom, it works fine with other tools, except with ubl it don't work. (I successed only to unlock a w220 with ubl)
I tried tonight with c261, I got the same errors as above.
Ubl team thinks that the solution passes through the cable lol. Compare UBL with other tools about ODM and CONCLUDE
Best regards,
Aishur
Old 07-21-2007, 22:44   #9 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
Originally Posted by Aishur View Post
Hi
Best regards,
Aishur
UFS with DirectCOM will work only in NEW ODM models ! Read sticky thread about ODM cable and CONCLUDE.
Old 07-21-2007, 22:50   #10 (permalink)
Member: 255072
Thanks Meter: 46
then problem sometimes pl2003 devices cross please unplug all cables when using usb to serial convertes using
Old 07-21-2007, 22:51   #11 (permalink)
Member: 255072
Thanks Meter: 46
arkadaşım com ayarlarından hız ve bağlantı ayarklarını defaults veya varsayılan ayar yap düzelir
Old 07-21-2007, 23:09   #12 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
Hi
I just red again this thread. We must conclude after exprimentation under the same conditions, try ODM with mstool and you will see that there is a big problem with UBL. Open a new thread and ask users if they are satified with ODM. you will see that they are mostly unhappy
Best regards,
Aishur
Old 07-21-2007, 23:14   #13 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
Hi
Best regards,
Aishur
UFS connection it's not ubl problem, with UBL ODM cable all works ok. Why users may be unhappy? UBL comes as tool for P2K moto, ODM was free addon. Are you always unhappy with free gifts ?
Old 07-21-2007, 23:51   #14 (permalink)
JHON_DREAM's Avatar
Member: 310330
Sonork: 100.1577334
Thanks Meter: 1,449
How can u said that its P2K baised moto tool ? & ODM is free ?
we see that ubl team said Complete Motorola phones servicing device in the ultimabox.org. main page .
so tell me if its gives some problem in ODM series & user r wants to discuse that, than its not right ans " ODM was free addon. Are you always unhappy with free gifts ?".
do u abale to work perfectly all ODM series in UBL ?
BEST OF LUCK,
JHON.
Old 07-22-2007, 00:16   #15 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
Hi
@JHON_DREAM
Thanks mate for your support, I would not to biker here and to answer him, but I must say who am I.
I am a clean man, I don't accept gifts. If I would have somethings, I buy it.
I am a pro and not a sunday unlocker or a stupid boy
About happiness
Users are unhappy look here
Look again here where nobody( you included) will make a bail for V3i pds repair will work.
Best regards,
Aishur
Motorola C139 unlock code help falle87 Motorola ODM 2 11-09-2008 03:54
Enybody Provide Free Motorola F3 Unlock Codes Help!!! pufka Phone Unlocking Codes & Maps 9 08-04-2007 20:34
motorola c116 unlock pls help moorthy Motorola P2k 0 01-09-2006 12:46
Motorola C350 unlock (please help!) Braveheart1981 Phone Unlocking Codes & Maps 7 07-28-2004 23:01
motorola c333 unlock code help!!!! RDNXHACKR Phone Unlocking Codes & Maps 0 09-08-2003 15:54
Page generated in 0.24769 seconds with 10 queries
