Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultima Box Light
Old 03-20-2009, 13:02   #1 (permalink)
UBL Support's Avatar
Member: 420649
Thanks Meter: 414
Motorola ODM USB Locosto drivers instalation procedure
Here is USB Drivers installation procedure for Motorola Locosto USB based models :
- Download "Motorola_Internal_Driver_Installation_3.7.0" from here:
http://www.ultimabox.org/Motorola_In...tion_3.7.0.msi
- Start "Motorola_Internal_Driver_Installation_3.7.0" and install it
- Press "Start -> Programs -> Motorola Driver Installer -> Motorola Driver Installer.exe"
- Select "Clean and Reinstall"
- Restart your PC
At this point you can connect your Motorola Locosto USB in Powered OFF state to PC USB port.
Drivers should be installed automatically.
In case you have damaged registry, You will have to install driver manually.
Follow this procedure:
- Start Device Manager (Right click My Computer -> Manage -> Device Manager)
- Connect Powered OFF phone to PC USB port
- In Device Manager, "Locosto" device will apear
- Double click on it, select "Driver" then click "Update Driver"
- Driver wizard will start, select "Install Driver from Specific Location"
- Press next and point wizard to "\\Program Files\Common Files\Motorola Shared\MotPCSDrivers\Drivers"
- Drivers installation procedure will be finished
Important note for Smart Clip users:
Beacuse SmartMoto damage windows registry and inf files, You'll have to run special utility to clean system from this:
- Download "Clear_SC_Driver.rar" from here: http://www.ultimabox.org/Clear_SC_Driver.rar
- Unpack, execute it and click "REMOVE"
- Restart PC and make USB Locosto installation procedure described here
The Following 42 Users Say Thank You to UBL Support For This Useful Post:
SEMC Usb Flash drivers installing problem! MUNEEB_AKHTAR_RAZA SETool2 11 07-23-2017 09:28
Motorola-W-***-USB-Modem-Driver rajtelecom Smart-Clip 1 06-26-2008 15:56
Urgent: Motorola V3 USB MODEM DRIVER for keypad fix FLEX (on Multiflasher) kingmobilephone Motorola P2k 3 07-20-2005 08:21
I need motorola c336 usb modem driver momento Motorola P2k 0 06-21-2003 08:43
Page generated in 0.14931 seconds with 9 queries
