03-04-2007, 21:39 | #95 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | V3r without TP Bootcore version on handset: 0A30 This Log : Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Save flash backup Finded fake sign address: 10004958 Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Sending RAMDLD to handset RAMDLD started ok in handset Set handset to blank mode Power down handset Set Blank Mode completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x0020880E Direct unlock method selected Started unlocking sequence Power down handset Unlocking sequence completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file Sending RAMDLD to handset RAMDLD started ok in handset Recover handset from blank mode Power down handset Handset recovered from blank mode Easy Skip TP unlock finished ok |
03-15-2007, 17:57 | #98 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | E770 unlocked witout TP : Switch handset to FLASH interface FLASH Interface established ok Bootcore version on handset: 0681 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0681 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Finded jump address: 10003B8C Save flash backup Power down handset Establish connection to handset Err no: 02020003 FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0681 Sending RAMDLD to handset RAMDLD started ok in handset Set handset to blank mode Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Try to load backup file Write flash to handset Power down handset Set Blank Mode completed ok Establish connection to handset FLASH Interface established ok Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Started unlocking sequence Power down handset Unlocking sequence completed ok Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Try to load backup file Recover handset from blank mode Power down handset Handset recovered from blank mode Easy Skip TP unlock finished ok |
03-18-2007, 15:20 | #100 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Unlocking using TP V3r (R3443U5_G) Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Sending RAMDLD to handset RAMDLD started ok in handset Read Flash chip type and ID Flash chip ID detected: 0x00898810 Direct unlock method selected Started unlocking sequence Power down handset Unlocking sequence completed ok |
03-23-2007, 18:43 | #103 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | W220 unlocked : Phone should be powered OFF Open serial interface COM1 Please press and HOLD power ON button Release power ON button Loader sent OK Unlocking phone ... Flash ID: 8900648801000100 SW version: SCY-7-1120-000 Patching firmware ... Connecting in AT mode ... Reading codes ... NCK: 59221657 NSCK: 03136675 SPCK: 03136675 CCK: 03136675 PCK: 03136675 FSCK: 03136675 Unlock OK Please remove/insert battery |
03-24-2007, 17:51 | #104 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 420820 Status: Offline Thanks Meter: 71 | Unlocked V3 R374_G Boot 0826 & Boot 07A0 V3r R4515_G Boot OA30 V3i R479_ Boot 0A30 V3X R252211LD_U Boot 0671 L6 R3511_G 08DO L7 R4513_G 08DO K1 R4527_G OAB2 with Magic TP adapter UBL ROX |
03-30-2007, 17:28 | #105 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | moto C140 Phone should be powered OFF Open serial interface COM1 Please press and HOLD power ON button Release power ON button Loader sent OK Unlocking phone ... Unlock OK Please remove/insert battery |
Please Post Here SuccessFully Unlock Phones With Samsung Rocker | MOBIL CLINIC | Rocker Dongle (By Legija) | 1 | 11-22-2009 20:24 |
Please Post Here SuccessFully Unlock Phones With Spt-Box | MOBIL CLINIC | SPT BOX | 1 | 11-01-2009 18:41 |
Please post here ur tested chines miracle phone in INFINITY | reaz.com | Infinity-Box | 3 | 10-10-2007 09:31 |
Please Post Here All The Bug's in Griffin which you face up todate.. | MicrostarGSM® | Griffin | 127 | 02-26-2005 10:55 |
