09-16-2007, 13:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 73
Member: 157657 Status: Offline Thanks Meter: 70 | Problem flash V3i-iTunes V3i (iTunes) if switch on, inner and outer LCD nothing apear, only keypad light lit, follow by vibrator. Can receive call. Use RSD LITE, ditected, Device Properties: IMEI: 352503011289755 Technology: Quad-Band GSM Software Version: R47A_G_08.D8.88R Flex Version: GSPSLQAT677DW0D8 - 1.0.1.3.1.5.0.6.S.0.0.0.1.0.0.6.B.4.3.0 Bootloader Version: N / A DRM Version: 0101 Bound Signature: Not Allowed Use UBL MotoRocker v2.20, via magic test point, write flash file “R47A_G_08.D8.88R_PDS005_LP0021_DRM0101_VSTUK_ENGL ISH206_1FF.sbf”, after erase flash… then error.. Split input file in codegroups Processed 8 codegroups Major Boot version supported by RAMLDR: 0A40 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Err no: 1120004 Err no: 1250004 Before do flash, allready restore boot loader to 0A.30 and Reapir pds, it’s ok.! Before do flash, at right bottom, detected: V3i-BLANK During process, it change to: V3i-FLASH And after get error.. it change to: V3i-MEM_CARD Flash with same version (88R) use RSD LITE 3.7, also cant work (Failed flashing process.Phone(0000):Incompatible…) What have I done wrong…? or Maybe there is h/w problem....? Thnx.. |
V3i iTunes downgrade problem | Speederer | Smart-Clip | 2 | 04-03-2008 08:46 |
Help Me Flash V3i Non-itunes To Have Itunes | lacasapc | Motorola P2k | 0 | 10-17-2006 14:26 |
HELP ME!!!! FLASH V3i itunes whit non itunes firmware | freeedomhouse | Motorola P2k | 6 | 09-08-2006 05:41 |
newbie have a problem flashing v3i | soda | Motorola P2k | 3 | 04-06-2006 16:42 |
need v3i r47a flash with itunes | japunlock | Motorola P2k | 2 | 03-21-2006 04:50 |
