09-02-2007, 22:32 | #1 (permalink) |
Junior Member Join Date: Aug 2007
Member: 577002 Status: Offline Thanks Meter: 0 | Using Easy Test Point Just got my UBL and have been searching for manuals how to use the box and finally found mr999 manual. however, it does not clearing specify the use of easy TP. Suggestions - Many of us out there are new comers to GSM unlock game and it would be of great interest of the manual be updated to with (1) Explain fullly what each data under "Backup" tab does or backsup (2) nothing about restore is mentioned (3) The use of TP should be set clearly, so we don't damage our phones, please note that any wrong use of this option will kill the phone. So explain more. I have spent almost all day searching this forum for a detailed use of the TP but couldn't find any really steps. This post might not mean any thing for the 'know how' guys out there but would mean alot for the new comers like me. So Please, both the experts and UBL team do some thing about this to avoid us killing our or customers. thanks 4 ur understanding. |
09-02-2007, 22:51 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: Poland
Member: 123230 Status: Offline Sonork: 100.113333 Thanks Meter: 14 | Magic TP: plug Magic TP to phone, connect power supply to phone, press button on Magic TP and at the same time plug usb cable to phone, when cable is plugged in you can release button on Magic TP. Standard testpoint: Connect Easy TP cable as power supply (don't press button on it), connect TP needle to testpoint on phone, press button on Easy TP cable, plug usb cable to phone, release TP needle from phone. |
09-03-2007, 09:13 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | """""Magic TP: plug Magic TP to phone, connect power supply to phone, press button on Magic TP and at the same time plug usb cable to phone, when cable is plugged in you can release button on Magic TP. Standard testpoint: Connect Easy TP cable as power supply (don't press button on it), connect TP needle to testpoint on phone, press button on Easy TP cable, plug usb cable to phone, release TP needle from phone"""""" thank you pecel. but after connect Magic TP to phone you say connect power supply to phone! witch power supply? external power supply or using for exemple easy tp cable as power supply? now how to know that Tp connection work before release button then start unlock? concerning easy tp cable, after some operation with my easy tp cable, know light on that button not still on again i don't know why? can it be a problem if don't light again? |
09-03-2007, 09:17 | #5 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | thank you pecel. but after connect Magic TP to phone you say connect power supply to phone! witch power supply? external power supply or using for exemple easy tp cable as power supply? now how to know that Tp connection work before release button then start unlock? concerning easy tp cable, after some operation with my easy tp cable, know light on that button not still on again i don't know why? can it be a problem if don't light again? |
09-03-2007, 16:00 | #6 (permalink) |
Member: 577002 Status: Offline Thanks Meter: 0 | Thanks all 4 all replies - But you said plung cable to phone, which cable? I thought the cable should go to the PC USB port. My question was really as to where should i connect the red and black cable and the pin to make TP GND? Please explain more as to where these three cables should go. there is a red and black cable and also 1 like a pin. thanks |
09-03-2007, 16:24 | #7 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | connect red cable to (+) of battery connector then you connect black cable to (-) of battery connector.plug usb cable to any free usb port of computer and the third cable with needle to TP point of phone pcb. that all. |
09-03-2007, 17:19 | #8 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
Br | |
09-03-2007, 18:22 | #10 (permalink) |
Junior Member Join Date: Sep 2007
Member: 579910 Status: Offline Thanks Meter: 0 | HI Mr999 can u plz send me the unlock code for ultra mp3. IMEI;354844014148954 my id is [email protected] i'll be waiting for ur reply |
09-03-2007, 19:09 | #12 (permalink) | |
Br | |
i need easy test point for n80..? | communication_expert | MT-BOX | 4 | 12-17-2007 08:26 |
UID BOX+Free dejan software= Easy Test point for free!!! | sheryngan | Nokia Base Band 5 ( BB-5 ) | 35 | 09-11-2007 21:24 |
How to use a Motorola V3 series Easy Test Point ? | klantech | Smart-Clip | 3 | 07-20-2007 16:02 |
Unlocking With Ubl Easy Test Point | SAM5 | Ultima Box Light | 7 | 02-12-2007 12:28 |
X55/X65 UFSX Easy test-point Cable ? | [c]Cinek | SST-Dongle | 0 | 08-07-2005 02:19 |
