08-15-2007, 09:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | V3 in BLANK Mode Any Ideas? |
08-19-2007, 11:47 | #5 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420649 Status: Offline Thanks Meter: 414 | If restored bootcore and the full flash with 1FF and still in blank mode, you have to check for hardware damages. Usualy somebody else destroied PCB or components near testpoint area or flash chip is bad soldered. |
08-21-2007, 17:03 | #6 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 57
Member: 60668 Status: Offline Thanks Meter: 69 | Try to repair pds with usb smart P2k v5.3 then flash with 1FF file. I have encountered same problem when i directly unlock v3 with v8.26 bootcore that leave the phone in blank mode, I cannot repair the pds section with ubl but with usb smart, its just a click. |
08-26-2007, 15:11 | #8 (permalink) |
Crazy Poster Join Date: May 2006
Member: 276839 Status: Offline Thanks Meter: 11 | got d same problem too.. i have a v3 8.26 boot loader that now is in blank mode. i tried to unlock it b4 without tp enter in blank mode but 4got 2 back up bootcore. when i click unlock and follow the procedures then press leave blank. the unit does not power anymore even when pressing *,#,pwr on. only the keypad only lights up. i have try to click "repair" it had response and boot up to 100% but when trying to select 1FF files so i could flash d phone.. the software starts too hang up, it shows some ERR:10001802,10060104 "not responding" dear mates what could i do to bring the phone from the land of the dead??? pls help... tnx in advance |
08-26-2007, 17:14 | #9 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: Poland
Member: 123230 Status: Offline Sonork: 100.113333 Thanks Meter: 14 | Quote:
2. Repair with TP if you have problems. | |
08-28-2007, 07:21 | #10 (permalink) | |
Member: 60668 Status: Offline Thanks Meter: 69 | Quote:
This same procedure is what i did before the unit turns in blank mode, just follow what i post earlier, use original usb smart p2k 5.3, with crack v3.1 it cannot repair the pds section. ...bootcore will downgrade to v.7oe, but at least the unit is alive!!! | |
help urgently for v3 on blank mode..what i do? | razisamb | Ultima Box Light | 2 | 02-28-2010 12:27 |
L7 in Blank Mode but Error in Flashing... | jhox2 | Motorola P2k | 8 | 11-14-2008 05:56 |
v3r with bootloader 03.52 stuck in Blank mode.. | SicilianBoy | Smart-Clip | 4 | 12-24-2006 13:55 |
v3x always in blank mode | gorgans | Smart-Clip | 5 | 09-18-2006 09:12 |
V975 Stock in Blank Mode | dannyogolo | Motorola P2K (USB-Smart) | 4 | 07-16-2006 17:36 |
