08-31-2007, 14:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | V3i OA.30. R479_G.08.B4.38R Can't Flash!!! when put the phone in flash mode display Boot loader OA.30 R479_G.08.B4.38R after i select flash files and languages,then press flash, i have error :1110002,1240003. i try connect phone direct to pc and then direct to phone but the same result. i follow all instruction for flash but no way. what the problem? phone is detected by software normaly but can't flash. i try it it with usb smart crack and it start formated then i stop it because i don't have that version of flash for use in usb smart crack. it was just to test connection. so UBL can't flash V3i? Nb: i discover that this version don't need Tp so why it can't be flash? |
08-31-2007, 19:03 | #3 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | ok but the real problem with is that i don't know how to make TP when flashing. it is easy to make TP when unlock because when tp is well done, sft recognize it and then ask you to remove it bfore continue your operation.but for dead phone how to knw if all ok? befre start flash? i have easy Tp cable for UBl and also Magic TP from UBl but this last one i don't know how to use it.for easy TP if use it how to then put phone in flash mode before flash? that what i don't understand when flash by using TP. for unlock i can connect TP then remove when connect but fo flash not. |
08-31-2007, 21:51 | #4 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: Poland
Member: 123230 Status: Offline Sonork: 100.113333 Thanks Meter: 14 | Quote:
09-02-2007, 15:22 | #5 (permalink) | |
Member: 118601 Status: Offline Thanks Meter: 200 | Quote:
Please ,I need LP0021 for V3i ( R479 ver 08.B4.85R) | quybk | Motorola P2k | 23 | 05-13-2009 04:04 |
V3i Oa.30 Need Tp For Full Flash? | zone2 | Smart-Clip | 25 | 05-08-2008 13:36 |
V3i OA.30 R479_G08.B4 FLASH NEED | denard | Motorola P2k | 2 | 09-18-2007 18:24 |
