Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GOT (Gsm Online Tool) > GOT Motorola
Old 04-02-2007, 17:50   #1 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
don t use repair pds with v980,v975...
i always get problems after repairing pds !! last one is with 2 pieces v980 & v975 after repair directions keys not work and external display don t work !!!and i m not able anymore to do any action except using TP
hope this will help and bug will be solved !
br
Old 04-06-2007, 04:57   #2 (permalink)
Member: 142161
If you don't solve your problem contact me. I think I face the same problem some time ago and I have solution write down somewhere. I'll check if you need help.
Old 04-06-2007, 12:26   #3 (permalink)
infogsm's Avatar
Member: 18022
Sonork: 1574868
can you give your solution ?
br
Old 04-09-2007, 03:16   #4 (permalink)
MATRIX.REAL's Avatar
Member: 202333
Wink
br
hello friend
have u tryed to perform REPAIR PDS with TEST POINT or not ?
Old 04-09-2007, 03:49   #5 (permalink)
infogsm's Avatar
Member: 18022
Sonork: 1574868
for sure i did with TP but nothing change !! anyway problem solved again using smart clip and btw don't use GOT for unlock rainbow pog too !
br
Old 04-12-2007, 07:55   #6 (permalink)
Member: 142161
V975 joystick dont work and 2nd display either
1.- TP and Repair PDS with GOT
Establish connection to handset
FLASH Interface established ok
Bootcore version on handset: 0310
Sending RAMDLD to handset
RAMDLD started ok in handset
Read Flash chip type and ID
Flash chip ID detected: 0x00898810
Write PDS zone on flash chip
Rebuild PDS checksums on handset
Write Bootcore zone on flash chip
Power down handset
Rebuild PDS procedure completed ok
2.- Unlock with USB-Smart
Then with USB-Smart select V975 an make "unlock" with "Use TP" to downgrade bootloader to 5.F.1. Disconnect the phone when the bootloader 6.3.1 (?) has been downgraded to 5.F.1. Thats all.
Phone it's working againg.
Old 04-12-2007, 12:24   #7 (permalink)
infogsm's Avatar
Member: 18022
Sonork: 1574868
1-doing repair pds with TP using got will lead to joyestik and external problem!! so better don t do it
2-when you use TP to unlock v975 bootloader will not be changed !!! its changed only on normal way but after doing pds using GOT it will be impossible to unlock again normally
3-simply the solution is smart-clip that will repair pds and downgrade bootloader automaticly
br
V3i Totaly Dead After Repair PDS with USB SMART crack... LoveLess P2k Series 5 05-22-2008 18:06
repaire pds with scout Ramicom Scout 1 02-19-2008 11:17
help me after pds repair and falsh v980 not deteckted in falsh mod senkron24 Smart-Clip 6 08-17-2007 13:45
v300 dead after repair pds with smart-clip wizz25 Smart-Clip 13 02-08-2006 11:47
V980-v975 melyse P2k Series 0 08-17-2005 09:26
Page generated in 0.28140 seconds with 11 queries
