Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GOT (Gsm Online Tool) > GOT Motorola
Old 03-31-2007, 23:48   #1 (permalink)
Member: 273044
e1000 0xdab error after unlock
Hello all,
I tried to unlock an e1000 the other day with GOT, and after process the phone displays 0x1de and then reading through a few posts, i tried to recover using p2k easy tool and now i have error 0xdab. I cant see any real solution other than smart-clip.
Is there any other way i can recover this phone with GOT with TP or something?
I havent used any TP on this phone yet.
P.s I do have another working e1000 here if thats any advantage to me.
Or am i just better off finding someone with Smart-clip.
Any help appreciated.
Tony
Old 03-31-2007, 23:58   #2 (permalink)
MATRIX.REAL's Avatar
Member: 202333
ok
do on REPAIR TABS
SET BLANCK MODE >>> REPAIR PDS >>> REMOVE BLANCK MODE
if not work
u must FLASH IT ....
Old 04-01-2007, 00:07   #3 (permalink)
Member: 273044
Thank for your reply
Set blank mode returns an error
Establish connection to handset
FLASH Interface established ok
Read handset bootcore version
Bootcore version on handset: 0310
Error: 30030101
and rsd lite, mff, both wont work to flash pfone
How else would i flash it
Thank
Old 04-01-2007, 01:43   #4 (permalink)
Member: 202333
for PROCess that ... u must enter your phone on FLASH MODE by pressing *+#+power on and then do :
reunlock your phone again
or do SET BLANCK MODE >>> REPAIR PDS >>> REMOVE BLANCK MODE but with CHECK NORMAL TP MODE OR USING SKIP TP MODE
u must try and TRY again ...
FINAL STEP is to use TEST POINT METHOD
Old 04-01-2007, 14:00   #5 (permalink)
Member: 273044
Success, thanks heaps.
I chose e1000 model in GOT, unlock with TP (without using actual TP)
and then straight after chose unlock normal, which shows error. then straight over to the repair pds and worked like a charm.
phone now up and running great
Took a lot of trying different procedures but thanks to your advice
up and running now.
BR tony
Motorola E1000 0xDab error Microemission P2k Series 3 02-13-2007 21:06
e1000 0xDAB error cheesegrate Smart-Clip 4 09-19-2006 12:05
My-X5m error after unlocking Inovator SAGEM JTAG UNLOCKER 3 03-13-2006 17:58
how to repair maxon 6869 with a imei error after unlock with free lovelas 2000 alro Various 1 06-01-2001 00:40
BE1 v163 error after unlocking with Andro5.9 westerna Alcatel & TCL Old Models 7 03-16-2001 00:41
Page generated in 0.41673 seconds with 11 queries
