09-09-2007, 09:34 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 479254 Status: Offline Thanks Meter: 0 | Help, my V3R is messed up Originally it is. Boot Loader 0A.52 SW version R4515_G_08.BD.D3R I tried to unlock it using P2K Easy Tool 3.9 using the unlocked SP setting, it messed up. I tried to fix it by using P2K Easy Tool 3.9 using Full repair PDS zone (with DSP checksum). Right now everytime I put the battery on the phone, it goes to the bootloader and says Boot Loader 0A.30 SW version: Not Found I search all over the forums and other forums for fix and I tried many different ways. I have a one day GOT and tried to do a Repair PDS, with and without testpoint and the bootloader and the SW version is still 0A.30 and Not Found. I tried to flash nightfall_mp_r4515R4515_G_08BDD3R, and nightfall mp r4515, and V3r Repair Flash (by_ JaWaD) and the bootloader and SW version is still 0A.30 and Not Found. Split input file in codegroups Processed 8 codegroups Major Boot version supported by RAMLDR: 0A40 Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0A30 Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Flashing codegroups ... Flashing codegroup 'cg1.smg' to 10092000 Flashing codegroup 'cg2.smg' to 111C0000 Flashing codegroup 'cg3.smg' to 10040000 Flashing codegroup 'cg4.smg' to 11040000 Flashing codegroup 'cg5.smg' to 11F80000 Flashing codegroup 'cg6.smg' to 10E00000 Flashing codegroup 'cg7.smg' to 11FE0000 Restarting phone Done flashing Operation completed with success Am I missing something? I really need a step by step help and see if it is possible to fix this phone. Thanks! |
09-09-2007, 10:31 | #2 (permalink) |
Member: 479254 Status: Offline Thanks Meter: 0 | Ok, I used GOT and did Set Blank Mode, Repair PDS, and then Remove Blank Mode and the result is Bootloader: 0A.30 SW Version: R4515_G_08.BD.2AR_2 then after I take out the battery and put it back it goes back to SW Version: Not Found |
09-09-2007, 16:53 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | thankx for posting the results thank u very much NAEEM FAROOQUI. before doing anything to motorola mobile please take the info and safe the log of screen to recover from any thing done wrong. |
My smartclip is power up.. but not updating | Nokia-Shop | Smart-Clip | 7 | 10-19-2009 13:33 |
[help]my 6630 cannot start up | budakbaong | Nokia Hardware & Hardware Repair | 0 | 10-19-2009 10:19 |
Installed Crusier and Now my Labtop is messed up!! need help! | Alpha_Wirelesss | Cruiser Suite | 5 | 04-07-2006 00:40 |
2 GD55's...one's wap is messed up, could i.... | wingh2daizzo | Panasonic | 1 | 04-04-2003 20:40 |
