05-14-2008, 10:47 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 770896 Status: Offline Thanks Meter: 0 | V3x: unable to remove "blank mode" I have tryed to restore a dead V3x with damaged bootcore (0301), which is in "blank mode", with GOT function "Repair PDS": GOT writes and restores both of bootcore and PDS area, but phone stays in blank mode. When I try to remove blank mode, the program says that there isn't a backup for restoring phone in normal mode. Tryed everything, without success, now my credit is out. Can I fix this problem? Thanks in advice. P.S.: I'm sorry for my BAD english. |
05-14-2008, 22:12 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | just do the flashing of the mobile by using any other software/tool simple is that no other solution or here is no more support for this tool left NAEEM FAROOQUI. search for my posts in this thread u find some use full links |
05-15-2008, 14:22 | #4 (permalink) |
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | use 3.7 and SHX file to flash it other wise just make TP of it its easy coz there is no steel cover in this phone NAEEM FAROOQUI. |
05-16-2008, 14:58 | #5 (permalink) |
Member: 770896 Status: Offline Thanks Meter: 0 | I have maked TestPoint for each connection of this mobile to my PC and tryed to flash a .shx firmware, without changes. The only thing different is that I have used RSD Lite 4.2 and now I will try with 3.7 version. |
05-16-2008, 16:28 | #6 (permalink) |
Member: 770896 Status: Offline Thanks Meter: 0 | Nothing to do, RDS 3.7 fails as the newer 4.2. Also rewrited bootcore (Intel version, according to the flash chip label marked with the "i" logo on the phone motherboard) taken from this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=369538 and do a Repair PDS, and still same error on RDS Lite 3.7. What's wrong? |
MFI Multiloader Error!unable to disable suspend on USB & Unable to cast COM object??? | Diegoquijada | BlackBerry (RIM) | 20 | 04-18-2014 15:11 |
unable to remove security code | karamusa | Genie Universal | 1 | 02-28-2010 22:28 |
Unable to remove a perticular Software ( iContact ) | ZODI. | HTC & PDA WM( With Touchscreen) | 2 | 10-30-2008 21:16 |
unable to remove Wrong card in X660 | ASHIF | UST Pro II | 8 | 08-09-2006 20:25 |
T68i unable to remove Brand | Gervasoni | Sony Ericsson | 0 | 03-20-2005 13:02 |
