Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GOT (Gsm Online Tool) > GOT SEMC
Old 02-17-2007, 09:38   #1 (permalink)
Member: 70343
W300i unlock failure
I have a W300i cid49 red that is not unlocking. It gives error message "Failure code 1973178" . What does this mean, and how do I fix it?
Old 03-25-2008, 23:46   #2 (permalink)
Member: 570617
Post W300i Eroor Code
I had this same problem. I attempted twelve to fif**** times to unlock and flash the phone with no good result. At last attempt I fully charged five batteries. Every time it requested I remove the cable and battery I replaced the partially used battery with a fresh battery. This resulted in a successful unlock and flash.
I've found that 897E flash chip is very sensitive to current/voltage from the battery. The 2019 is much easier to deal with.
I've two 897E handsets that I was lucky to unlock, I had SEMC read the unlock codes and I manually entered them. I won't attempt to flash them. At every "trying to power on" I had to manually power on the handset and frequently had errors. With the 2019 handsets they came on by themselves.
If someone has a better understanding of the various flash chips in these handsets and would like to share their wisdom and knowledge I'd be glad to read it.
w300i unlock unlock prob troo Sony Ericsson 2 03-10-2007 14:50
SE w300i unlock solution malkjos Sony Ericsson 1 10-09-2006 12:23
SE W300i Unlocking Help Plzzzz :¬) Fonestuff Universalbox 4 09-15-2006 15:52
SE W300i Unlocking Help Plzzzz :¬) Fonestuff Universalbox 2 09-13-2006 03:39
W300i Unlock Problem. gsm500 SonyEricsson (USB-Smart) 8 08-24-2006 12:52
Page generated in 0.93465 seconds with 11 queries
