02-23-2008, 07:52 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 54
Member: 145807 Status: Offline Thanks Meter: 4 | Box Rebuild Problem - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - ERROR: SERVER'S OFF-LINE! AND IF I TRY TO USE THE UPDATE TOOL I GET THIS MESSAGE Lpt Port : 0x378 Status : Device not found! AT TIMES I GET THIS Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - ERROR: Rx DATA FROM SERVER! |
Sagmaster rebuild problem | umarfarouq | SagMaster Team OLD Products | 6 | 09-12-2008 04:33 |
Samsung U600 Imei Rebuilding Problem | M.YASIR | UST Pro II | 12 | 07-14-2007 15:24 |
sagmater rebuild problem | inaolaji abioye | SagMaster | 0 | 06-29-2007 12:23 |
C260 imei rebuild problem | huzsolt | HWK | 0 | 06-04-2007 11:55 |
C230 imei rebuild problem | meisam | UST Pro II | 1 | 09-22-2006 22:02 |
