Can not write flash in to MyX-5m Found Phone, Phone Info: - Phone Type: myX-5 GPRS - Phone FW: JE3,9I: 180303 1054 - Phone HT : 22 00 00 - Phone IMEI: - Phone Code: 00000000 (inactive) - Flash ID: 00 B0 00 B4 - Chip(0): Sharp LH28F320BFHG 32Mbit - Flash ID: 00 01 22 5C - Chip(1): AMD 29DL324DT 32Mbit Write 0x00010000 - 0x00400000...Done! Write 0x01000000 - 0x01230000...Done! - New Firmware: JE3,9I: 180303 1054(22 00 00) Update eeprom: - Connect phone ...Error! Update eeprom: - Connect phone ...Error! - MSG: OPERATION TERMINATE BY USER! Try check Repair Eeprom - got Sim locked without sim Then try repair with Sagmaster - Ok form forst attempt |
enter try ons again please why you close opeeration ? first read manual please SMT |
write flash to phone with repair eep SMT |
:confused: |
select repair eep please and write flash try please |
- Flash ID: 00 B0 00 B4 - Chip(0): Sharp LH28F320BFHG 32Mbit - Flash ID: 00 01 22 5C - Chip(1): AMD 29DL324DT 32Mbit Write 0x00010000 - 0x00400000...Done! Write 0x01000000 - 0x01230000...Done! Write 0x01230000 - 0x01400000...Done! - New Firmware: JE3,9I: 180303 1054(22 00 00) ***************************************** Phone show Sim Locked without SIM, I'm sorry client needed his phone urgently, no phone in this moment |
i think that you havn't flash it correctly ,,,because i have just try 3 X5-m and all was ok ,, best regards to SAGMASTER |
***************************************** JOB "DETECT PHONE": Found Phone, Phone Info: - Phone Type: myX-5 GPRS - Phone FW: JF3,9G: 110703 1756 - Phone HT : 22 00 00 - Phone IMEI: 353054001090612 - Phone Code: 00000000 (inactive) - Flash ID: 00 B0 00 B4 - Chip(0): Sharp LH28F320BFHG 32Mbit - MCP Flash ID: 00 01 22 7E 22 0A 22 01 - Chip(1): AMD 29DL320G 32Mbit ***************************************** JOB "READ CODE": Skip......... - L00 hex: 0xDABCD750 dec: 36698089-76 - L40 hex: 0x9AFD61EF dec: 26002969-43 Clear Net Code...Done! ***************************************** JOB "READ FLASH(S)": Skip...... Read 0x00000000 - 0x00400000...Done! Read 0x01000000 - 0x01400000...Done! ***************************************** Select flash file - myX-5m_JF3,9H 130803 1056(22 00 00)_251323904 (Hung; Croa; Russ; Slva; Poli; Roma; Engl; Slov).ufl ***************************************** JOB "WRITE FLASH(S)": Skip...... Write 0x00010000 - 0x00400000...Done! Write 0x01000000 - 0x01230000...Done! - New Firmware: JF3,9H: 130803 1056(22 00 00) Update eeprom: - Connect phone ...Error! Update eeprom: - Connect phone ...Error! Update eeprom: - Connect phone ...Error! Update eeprom: - Connect phone ...Error! Update eeprom: - Connect phone ...Error! - MSG: OPERATION TERMINATE BY USER! ***************************************** Phone work with - Sim locked without sim. Then.... ***************************************** JOB "READ CODE": - ERROR: UNEXPECTED DEVICE EXEPTION! ***************************************** JOB "DETECT PHONE": - ERROR: UNEXPECTED DEVICE EXEPTION! ***************************************** JOB "WRITE FLASH(S)": - ERROR: UNEXPECTED DEVICE EXEPTION! ***************************************** You help me? :-) |
Can not flash Yes, i have this errors too To Gsminfo This phones have - Chip(0): Sharp LH28F320BFHG 32Mbit - Chip(1): AMD 29DL320G 32Mbit Please, test SMTi with this chips :) |
@Potvora give me few min I check after 1h please wait SMT |
@Potvora Sorrry . You have right . little bug in flash file generator for this model . Please wait . SMT |
Bug So I and sph402 needs redownload flash files for tihs model ? |
hi i have one myx100 hardware failure,when i try to detect fone it tells me fone not found.can anyone help me out pls' |
@Potvora we add x5m correct flash after few hours Please wait @Kobby Check data connector , use cable from C2 series Phone must be ON SMT |
Download new firmware. Reflash use recalc EEPROM: Found Phone, Phone Info: - Phone Type: myX-5 GPRS - Phone FW: JF3,9H: 130803 1056 - Phone HT : 22 00 00 - Phone IMEI: 353054001090612 - Phone Code: 00000000 (inactive) - Flash ID: 00 B0 00 B4 - Chip(0): Sharp LH28F320BFHG 32Mbit - MCP Flash ID: 00 01 22 7E 22 0A 22 01 - Chip(1): AMD 29DL320G 32Mbit Write 0x00010000 - 0x00400000...Done! Write 0x01000000 - 0x01230000...Done! - New Firmware: JF3,9H: 130803 1056(22 00 00) Update eeprom: - Connect phone ...Ok! - Get old data ...Ok! - Update language field ...Ok! - Update T9 field ...Ok! - Get CheckSum count ...12 - Clear Net Lock ...Ok! - Update field 5250 ...Ok! - Update CheckSum 16128 <=> 5251 ...Ok! - Update CheckSum 16129 <=> 5252 ...Ok! - Update CheckSum 16140 <=> 5253 ...Ok! - Update CheckSum 16141 <=> 5254 ...Error! - ReBoot Phone ...Done! Update eeprom: - Connect phone ...Ok! - Get old data ... - Update language field ...Ok! - Update T9 field ...Error! - ReBoot Phone ...Done! Update eeprom: - Connect phone ...Error! - MSG: OPERATION TERMINATE BY USER! Reflash use REPAIR EEPROM: Found Phone, Phone Info: Skip...... Write 0x00010000 - 0x00400000...Done! Write 0x01000000 - 0x01230000...Done! Write 0x01230000 - 0x01400000...Done! - New Firmware: JF3,9H: 130803 1056(22 00 00) Use Read code : Found Phone, Phone Info: Skip.... - L00 hex: 0xDABCD750 dec: 36698089-76 - L40 hex: 0x9AFD61EF dec: 26002969-43 Clear Net Code...Done! Phone work. Thanks! |
