03-06-2010, 15:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | succes unlock mY301X... v.rom :0411 hash :B1078B763859395EFE207A039E4A2FD8 dieid :271545F3B75A02E6 - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my301X - Phone FW :LB5,4C: 200905 2045 - Phone HT :60 7C 01 - Phone IMEI :356710000144026 - Phone Code :0000 (inactive) - Prod. Code :252284482 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :41849756-84 - Net Hi code :31154282-28 - Connect phone ...Ok! - Clear Net Code...Success! |
The Following 4 Users Say Thank You to chimed09 For This Useful Post: |
04-19-2010, 17:51 | #3 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | and succes unlock my401x... Code: POWER ON PHONE ...Ok! v.rom :0411 hash :4F9C42E2FB1232BDFAF5F81421FD14C1 dieid :111806EEB05104FB - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my401X - Phone FW :LB5,BH: 080306 1731 - Phone HT :BC 20 01 - Phone IMEI :358199003423991 - Phone Code :1984 (active) - Prod. Code :252418525 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :24779317-37 - Net Hi code :35474793-21 - Connect phone ...Ok! - Clear Net Code...Success! |
07-20-2010, 20:40 | #4 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | My301x... POWER ON PHONE ...Ok! v.rom :0411 hash :41714D4044CC22EC9F5BE645F49AF7B9 dieid :1F238EE4635204C1 - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my301X - Phone FW :LB5,4C: 200905 2049 - Phone HT :60 7C 01 - Phone IMEI :356710003013301 - Phone Code :0000 (inactive) - Prod. Code :252284482 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :23359781-67 - Net Hi code :34223028-39 - Connect phone ...Ok! - Clear Net Code...Success! |
07-30-2010, 19:46 | #5 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | My301x.......... POWER ON PHONE ...Ok! v.rom :0411 hash :27DD54863D60FF47A360586F4B0F7669 dieid :1B225075B55A02CE - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my301X - Phone FW :LB5,4C: 200905 2050 - Phone HT :60 7C 01 - Phone IMEI :356710008267779 - Phone Code :0000 (inactive) - Prod. Code :252284482 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :35807442-71 - Net Hi code :25111968-15 - Connect phone ...Ok! - Clear Net Code...Success! |
The Following 3 Users Say Thank You to chimed09 For This Useful Post: |
10-03-2010, 16:53 | #6 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | My101x.... Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my101X - Phone FW :JA3,YL: 230506 1054 - Phone HT :58 20 01 - Phone IMEI :358540005540714 - Phone Code :00000000 (inactive) - Prod. Code :252441222 - Board Type :m62 - NOR Flash ID :00BF 734B - Chip [0] :SST 36VF1601E 16Mbit Get Code from server ...Success! - Net Lo code :21313045-93 - Net Hi code :10617570-09 - Connect phone ...Ok! - Clear Net Code...Success! |
10-29-2010, 19:46 | #7 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | myX3-2 Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myX3-2 - Phone FW :JA3,JB: 171203 1945 - Phone HT :22 00 00 - Phone IMEI :352860003587780 - Phone Code :00000000 (inactive) - Prod. Code :251640462 - Board Type :m62 - NOR Flash ID :0001 227E 2202 2201 - Chip [0] :AMD 29DL640G 64Mbit Get Code from server ...Success! - Net Lo code :17895587-91 - Net Hi code :07189427-62 - Connect phone ...Ok! - Clear Net Code...Success! |
11-23-2010, 18:15 | #8 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | My V56... Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myV-56 - Phone FW :KB3,ZF: 040705 1605 - Phone HT :84 08 01 - Phone IMEI :356107001410912 - Phone Code :00000000 (inactive) - Prod. Code :252152255 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :26280665-10 - Net Hi code :36976142-22 - Connect phone ...Ok! - Clear Net Code...Success! - Clear Code Counter...Success! |
12-16-2010, 14:46 | #9 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | C5-2v... Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myC5-2v - Phone FW :LA5,8F: 110106 1908 - Phone HT :13 01 01 - Phone IMEI :352405010467160 - Phone Code :0000 (inactive) - Prod. Code :252768793 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :18908502-53 - Net Hi code :08213026-69 - Connect phone ...Ok! - Clear Net Code...Success! |
01-26-2011, 15:58 | #10 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | my100X Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my100X - Phone FW :JA3,YD: 040106 1620 - Phone HT :31 04 01 - Phone IMEI :358190005253965 - Phone Code :00000000 (inactive) - Prod. Code :252443445 - Board Type :m62 - NOR Flash ID :0001 2236 - Chip [0] :AMD 29DL161DT 16Mbit Get Code from server ...Success! - Net Lo code :27792648-73 - Net Hi code :38488122-01 - Connect phone ...Ok! - Clear Net Code...Success! |
02-23-2011, 15:59 | #11 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | myX-4t... Read Phone Info ...Done Found Phone, Phone KE3,NL: 070Info: - Phone Type :myX-4 - Phone FW :605 1411 - Phone HT :B2 01 01 - Phone IMEI :355227001504521 - Phone Code :0000 (inactive) - Prod. Code :252031831 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :19219513-91 - Net Hi code :08524038-07 - Connect phone ...Ok! - Clear Net Code...Success! |
04-06-2011, 16:08 | #12 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | my401Ci POWER ON PHONE ...Ok! v.rom :0502 hash :62FB6505AC902905678D99DD748702EE dieid :2160020C87395AC10000000000006204 - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my401Ci - Phone FW :LI5,QP: 160307 1745 - Phone HT :94 20 05 - Phone IMEI :353415011170522 - Phone Code :0000 (inactive) - Prod. Code :252966584 - Board Type :m63 - NOR Flash ID :0001 2D7E 2D2F 2D00 - Chip [0] :Spansion S29NS256N 256Mbit Get Code from server ...Success! - Net Lo code :35912002-52 - Net Hi code :25216525-40 - Connect phone ...Ok! - Clear Net Code...Success! |
The Following User Says Thank You to chimed09 For This Useful Post: |
05-10-2011, 18:07 | #14 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | my301X.... POWER ON PHONE ...Ok! v.rom :0411 hash DEAF89D47DC2F912BC7CA8DBB8D892E dieid :1E2C4BF3B75A02F0 - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my301X - Phone FW :LB5,4C: 200905 2045 - Phone HT :60 7C 01 - Phone IMEI :356710000294102 - Phone Code :0000 (inactive) - Prod. Code :252284482 - Board Type :m62+ - NOR Flash ID :0001 227E 2221 2201 - Chip [0] :AMD S29GL128NH/L 128Mbit Get Code from server ...Success! - Net Lo code :41318195-84 - Net Hi code :30622721-28 - Connect phone ...Ok! - Clear Net Code...Success! |
05-20-2011, 18:42 | #15 (permalink) |
Member: 479816 Status: Offline Thanks Meter: 851 | my300C... POWER ON PHONE ...Ok! v.rom :0502 hash :62FB6505AC902905678D99DD748702EE dieid :14600116971556C1000000000000324A - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :my300C - Phone FW :LI5,PB: 160707 1420 - Phone HT :73 34 05 - Phone IMEI :355437018240205 - Phone Code :0000 (inactive) - Prod. Code :252982893 - Board Type :m63 - NOR Flash ID :0001 327E 3243 3200 - Chip [0] :Spansion S29NS128P 128Mbit Get Code from server ...Success! - Net Lo code :10504833-42 - Net Hi code :21200307-98 - Connect phone ...Ok! - Clear Net Code...Success! |
E75 unlock error at the finish but Succes Unlock The phone | ServiceTEL | Universalbox | 0 | 05-12-2009 17:37 |
how to unlock my301x ?? | patric | SAGEM JTAG UNLOCKER | 6 | 11-29-2007 23:17 |
unlock my301x | osama | SwS_SaG_BoX | 0 | 05-22-2006 15:40 |
Unlock My301X | keeper7 | ARM9 BASED M62 / M62+ | 0 | 01-12-2006 10:47 |
