Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SMTi Support Sections > SMTi
Old 03-31-2008, 13:34   #1 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 12
my x6-2 sim locked after flash with or without sim card
a already flashed the phone using direct write and repair eeprom
when all finished i'm having now sim locked with or without sim card
here is the log
Found Phone, Phone Info:
- Phone Type :myX6-2
- Phone IMEI :355450004645295
- NOR Flash ID :0001 227E 2222 2201
- Chip [0] :AMD S29GL256NH/L 256Mbit
Write Flash Data ...Done!
- New Firmware: L25,1G: 210306 1056(80 04 01)
and credit are token
so what can i do now to solve the problem
thanks in advance
Old 03-31-2008, 13:36   #2 (permalink)
GsmFreeShop's Avatar
Member: 567723
Thanks Meter: 314
finalise your flash bro and all will be ok
it's take logs
br
>>> GsmFreeShop <<<
Old 03-31-2008, 13:41   #3 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 12
so i just make finalise flashing without writing firmware???
Old 03-31-2008, 14:23   #4 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
write flash with finalize
Old 03-31-2008, 16:40   #5 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 12
According to what I have concluded, "direct write+repair eeprom" don't solve completely the problem, so i must reflash in normal mode (firmware+finalise flashing+recalculate eeprom) and loose 4 credit!!!!!
thanks for help problem solved
Old 04-05-2008, 17:43   #6 (permalink)
Member: 268772
Thanks Meter: 102
Finalize it after flashing....
it will b ok
Old 04-05-2008, 18:19   #7 (permalink)
A1 Cell Solution's Avatar
Member: 25759
Thanks Meter: 159
even i got one my x6-2 sim today just white light blinking culdnt connect in normal mode so flashed using direct write option after flashing set on but with simlock without sim & one credit
deducted flashed again in normal mode using write firmware and finalize flashing option with recalculate eeprom checked phone unlocked and working normal 2 more credits deducted
I just want to ask the product supporters is this the right way to repair the set as total of 3 credits were used in reviving the set or did i do something wrong
is there any way to repair the set just using 2 credits or dead set always takes 3 credits
regards
jagjit
Old 04-05-2008, 18:36   #8 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
Thanks Meter: 2,843
@A1 Cell Solution
(deducted flashed again in normal mode using write firmware and finalize flashing option with recalculate eeprom checked phone unlocked and working normal 2 more credits deducted)
I Will Answer You By Another Question !! IF SMTi SOFTWARE DEFAULT SELECTION OF "myX6-2" = Write Firmware Options :
-Write Firmware
-Finalise Flashing
-Recalc Eeprom
Why manually changing default recommended Software Options , that SMTi will not take credits ???!!
Any model Selection in SMTi Software can have Own default Options , so if Already model have Finalise not mean to uncheck this option then phone will be flashed & repaired without take credit .
SMTi Software make this Full Job with 2 Credits , Flashing Phone + Repair + Unlock & Reset All Locks !! But without Play of course
Old 04-07-2008, 13:47   #9 (permalink)
Member: 682988
Thanks Meter: 45
the 2 credits must be taken when software do finalize!!! (to have a working phone, finalize must be done)
me too, 3 credits was taken just for one phone!
it's not correct from you!
Old 04-12-2008, 03:32   #10 (permalink)
Member: 52847
Thanks Meter: 64
hi
hi
u can take 2 credits for imei coz if we have anyy error we can try again in the same imei for free ...................
how can i repair my-v55 sim locked without sim inside after flashing with sws-sag asmar Redbox 8 02-06-2006 00:38
Sagem MW 936E Sim not present with or without sim card florinmar Infineon C16X M51 & ARM7 M52 BASED 7 11-04-2002 14:43
Please help Sagem MC930 sim locked with or without sim florinmar Infineon C16X M51 & ARM7 M52 BASED 1 02-04-2002 16:36
Is the full flash C45 v 06 on Landy's page with or without sim-lock?? sifasli x1x to x45/x50 0 12-15-2001 22:35
Page generated in 0.49172 seconds with 8 queries
