10-30-2009, 16:14 | #1 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | myV-76 restart problem i had problem with sagem myV-76 every 5 or 10 mintus restart i changed the frimware but no hope here is the log operation: - Phone FW :LC5,1C: 150605 1942 - Phone HT :01 09 01 - Phone IMEI :356112000167604 - Phone Code :00000000 (inactive) - Prod. Code :251995502 - Board Type :m62+ - NOR Flash ID :0001 227E 2222 2201 - Chip [0] :AMD S29GL256NH/L 256Mbit Write Flash Data ...Done! Write Flash Data ...Done! - New Firmware: LK5,1E: 171105 1817(35 00 01) ------------------------------------------------------------ etect Phone: Found Phone, Phone Info: - Phone Type :myV-76 - Phone FW :LK5,1E: 171105 1817 - Phone HT :35 00 01 - Phone IMEI :356112000167604 - Phone Code :00000000 (inactive) - Prod. Code :251971700 - Board Type :m62+ - NOR Flash ID :0001 227E 2222 2201 - Chip [0] :AMD S29GL256NH/L 256Mbit Boot Method: "HS Device" Autodetect Operation Cost: - Clear/Set Net Code :1 Credit - Change Firmware :2 Credit P.S. GP Method Work Only USE "SMTi Virtual Port(COM0)" HS Method Clear User Code 1 Credit ***************************************** Write Flash: POWER ON PHONE ...Ok! v.rom :0411 hash :4FAD5F2781B11489F853888CC4A3D1AF dieid :120A0521B15702A6 - Load Certificate ...Ok! - Load Application ...Ok! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myV-76 - Phone FW :LK5,1E: 171105 1817 - Phone HT :35 00 01 - Phone IMEI :356112000167604 - Phone Code :00000000 (inactive) - Prod. Code :251971700 - Board Type :m62+ - NOR Flash ID :0001 227E 2222 2201 - Chip [0] :AMD S29GL256NH/L 256Mbit Finalise Flashing ...Done any idea plz?? |
10-30-2009, 16:56 | #2 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | by the way when i turn on the phone without sim card the phone run normel but when i insert sim card phone start up then aftert 5 mintues or more phone restart or shutdown b.r. |
myv-76 camera problem | lahdache | ARM9 BASED M62 / M62+ | 0 | 02-07-2009 21:14 |
MYV-76 Restart after flashing | samirrr | SMTi | 1 | 08-31-2008 15:18 |
myv-76 unlock problem | Sioma | SAGEM JTAG UNLOCKER | 1 | 04-16-2008 17:16 |
MYV-76 Testpoint??? and support??? | byteforce | SagMaster Team OLD Products | 1 | 09-26-2005 21:18 |
what about new model ( MYV-56 MYV-76 MYX2-2) | bozan | SagMaster Team OLD Products | 0 | 06-25-2005 01:42 |
