Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SMTi Support Sections > SMTi
Old 09-18-2009, 05:52   #1 (permalink)
Member: 709608
Thanks Meter: 14
myX2-2 Connect phone ...Error!
Read Phone Info ...Done
Found Phone, Phone Info:
- Phone Type :myX2-2
- Phone FW :JA3,LD: 240505 1035
- Phone HT :27 04 01
- Phone IMEI :35xxxxxxxxxxxxxx
- Phone Code :00000000 (inactive)
- Prod. Code :252100842
- Board Type :m62
- NOR Flash ID :0001 227E 220A 2201
- Chip [0] :AMD 29DL320G 32Mbit
Get Code from server ...Success!
- Net Lo code :32014263-76
- Net Hi code :42709738-32
- Connect phone ...Error!
always i got this error,kindly some one guide me pleaze
Old 09-18-2009, 07:05   #2 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
I think power suply some problem
write code manualy
SMT
The Following User Says Thank You to gsminfo For This Useful Post:
Old 09-19-2009, 06:02   #3 (permalink)
Member: 709608
Thanks Meter: 14
i gave power from power suplay about 5v
same error appear
any idea appreciated
- Board Type :m62
Old 09-19-2009, 07:07   #4 (permalink)
gsminfo's Avatar
Member: 23714
put code by keypad
SMT
Old 09-20-2009, 04:36   #5 (permalink)
Member: 709608
Thanks Meter: 14
i tried
only can enter 8 numbers
i think counter is blocked
no any other way?
Old 09-20-2009, 19:44   #6 (permalink)
gsminfo's Avatar
Member: 23714
Originally Posted by helperer View Post
i tried
no any other way?
I think you have "simlock" without sim card
If yes ... Read manual step by step HOW to repair software problem ...
manual
SMT
Old 09-21-2009, 04:24   #7 (permalink)
Member: 709608
Thanks Meter: 14
without sim card it says SIM fehht
with sim card it says sim lock and can enter 8 gigit number
will this flash work at this situation?
thanks
Old 09-22-2009, 16:14   #8 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
Thanks Meter: 2,843
@helperer
Correct word is "SIM FEHLT" = SIM is missing !
Try access phone with a Valid sim & then Press menu button followed by star(*) & hold , a menu will appear
there's an option about sim lock see if you can put Net code there or not ! if not , your mobile need repair !
The Following User Says Thank You to DZStorm For This Useful Post:
Old 09-23-2009, 04:35   #9 (permalink)
Member: 709608
Thanks Meter: 14
you are right
can put the code but only 8 numbers cannot put last two numbers
will it be okey when flash the mobile?
thanks
SDRII myX2-2 UNKNOWN PHONE ALGORITM! sjakie SagMaster Team OLD Products 5 10-02-2005 13:43
Page generated in 0.30064 seconds with 8 queries
