11-11-2009, 01:36 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 517387 Status: Offline Thanks Meter: 8 | Sagem myX1-2 unlock problem Here's my log: Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myX1-2 - Phone FW :JF3,VF: 140205 1049 - Phone HT :02 00 02 - Phone IMEI :xxxxxxxxxxxxxxx - Phone Code :00000000 (inactive) - Prod. Code :251947072 - Board Type :m62 - NOR Flash ID :0001 2236 - Chip [0] :AMD 29DL161DT 16Mbit Get Code from server ...Success! - Net Lo code :13931748-63 - Net Hi code :03320160-15 - Connect phone ...Ok! - Clear Net Code...Success! but phone still lock, any help will be appreciate. |
11-11-2009, 08:35 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | Get Code from server ...Success! - Net Lo code :13931748-63 - Net Hi code :03320160-15 - Connect phone ...Ok! - Clear Net Code...Success! All operatin 100% correct . I think you have problem with software . Please turn on your phone without sim card . You see "insert sim cards" or "simlocked" if you see "simlocked on LCD you need make repair sw problem . Manual how to repair all sw problem: http://www.sagmaster.com/download/11...20problems.pdf SMT |
11-11-2009, 23:47 | #3 (permalink) |
Member: 517387 Status: Offline Thanks Meter: 8 | Without sim I can read in display INSERT SIM CARD, with SIM inside INCORRECT SIM CARD, I do all the hole process 3 times, please helpme to solve my problem.What can I do? Thank's in advance. |
Sagem Myx6-2 Unlock Problems | COMMANDCOM | KULANKENDI Server | 13 | 05-27-2008 15:18 |
Sagem Myx2-2 Unlocking Problem | ethiomobile | ARM9 BASED M62 / M62+ | 3 | 03-22-2007 17:10 |
Sagem MYC-2 Unlocking Problem | bbmad | SwS_SaG_BoX | 2 | 02-24-2007 16:55 |
Sagem MyX2-2 unlock problem? | gpyson | ARM9 BASED M62 / M62+ | 4 | 09-12-2005 17:36 |
