11-12-2009, 09:45 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Sagem vf-533 on/off & network lock Problem I have Sagem vf-533 on/off & one is network lock But I can't Flash & Unlock. I am using latest version SMTi_Setup_17V71. When I select file which one I download support area but flashing process repeat like remove battery then power one still same network lock phone. Support team pleas solve my issue ASAP. One more think I download support area file name EVN,ZJ: 221008 1636 I get FTP error also solve this issue. Here is on/off phone info: Found Phone, Phone Info: - Phone Type :VF533 - Phone FW :EVN,ZJ: 221008 1637 - Phone HT :10 2C 07 - Phone IMEI :3546490XXXXXXXX - Prod. Code :254067392 - Board Type :m63 Boot Method: "HS Device" Autodetect Operation Cost: - Clear/Set Net Code :FREE (ballance >= 25)/1 Credit (ballance < 25) - Change Firmware :1 Credit (ballance >= 25)/2 Credit (ballance < 25) P.S. GP Method Work Only USE "SMTi Virtual Port(COM0)" HS Method Clear User Code 1 Credit Here is flashing Info just verifies but can't start flashing. POWER ON PHONE ...Ok! v.rom :0502 hash :731C27AB2AE00189FBD4FD3013B53252 dieid :38A00114967700C2000000000000B67D - Load Certificate ...Ok! - Load Application ... Here is lock phone info: Found Phone, Phone Info: - Phone Type :VF533 - Phone FW :EVN,ZJ: 221008 1638 - Phone HT :10 2C 07 - Phone IMEI :3546490XXXXXXXX - Prod. Code :254067392 - Board Type :m63 Boot Method: "HS Device" Autodetect Operation Cost: - Clear/Set Net Code :FREE (ballance >= 25)/1 Credit (ballance < 25) - Change Firmware :1 Credit (ballance >= 25)/2 Credit (ballance < 25) P.S. GP Method Work Only USE "SMTi Virtual Port(COM0)" HS Method Clear User Code 1 Credit Here is unlocking logs when I select clear net code and do code job. POWER ON PHONE ...Ok! v.rom :0502 hash :731C27AB2AE00189FBD4FD3013B53252 dieid :14C00202B17800C20000000000001649 - Load Certificate ...Ok! - Load Application ... I repeat both processes much time with fully charge battery. Its urgent. |
8300 how to unlock phone & network lock (Answered) | kasim | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 2 | 03-08-2010 06:40 |
w200 network lock problem | micro_hsr | Sony Ericsson Hardware Repair | 2 | 07-06-2009 16:54 |
D520 Power on-off & key-pads don't work | beneto | Samsung Hardware Repair | 0 | 05-24-2008 13:40 |
nokia 6101 only on off & menu key working. | sachin_udai | Nokia Hardware & Hardware Repair | 2 | 04-01-2008 08:20 |
siemens A55 network lock problem | chetangajjar | E-Gold Based Phones | 5 | 12-07-2003 10:43 |
