03-31-2010, 18:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | SMTi Ver 18.73 Released - JRT [JTAG Repair Tool] Module Added These injuries are manifested by a lack of communication with the computer USB, and thus prevent the uploading of new software because it was damaged Boot Loader, which is responsible for the communication device to the PC. The market is already such equipment but SMTi JRT distinguished feature of these devices Check Bad Sectors and Calculate Space. These functions are intended to before programming the new Boot Loader, check the area which is in the Flash memory partition is responsible for Boot'a. This makes it possible to circumvent the bad sectors in the memory, and upload correct Boot Loader, and thus repaired by a hundred percent. Description of the function 1. Boot Files Buffer: place for boot repair file selected. 2. JRT SUPPORT AREA: support area for boot files, pinouts,flash files etc ... 3. CPU CORE: CPU family type selected 4. Phone CPU: CPU type selected 5.Auto select the type of Flash memory in a damaged device. Models in the program are not a complete list of supported models by JRT! Always check JRT SUPPORT AREA for description of the JTAG and Boot Repair. Full list is given on the product support web and the support forum. 6. Other: Manual selection of the type of Flash memory in a damaged device. 7. JOB METHOD: Choosing the type of work the JTAG interface. 8. Start Option Auto Power: Feature that allows you to start the phone by the program . 9. Use Start INIT: The option to load the program LOADER SMTi zero if the sector flash memory is erased. Recommended Erase Boot execution and then select Use the Start INIT before programming the new Boot Loader. 10. Boot Size: Choose the size of the Boot Loader to be read from the device. . 11. Check Connection: Checking the correct connection JTAG'a to the device. 12. Read Boot: This function allows the Boot Loader to read from the device 13. Erase Boot: Function to delete the Boot Loader. Always after erasing the Boot Loader disconnect and reconnect the power supply in the damaged unit, and then before programming the new Home Use Boot'a select INIT and JTAG DCC 14. Write Boot: Function to upload a new Boot Loader SMTi JRT Adapter SMTi JRT ADAPTER - PinOuts Repair of the device with damaged Boot Loader 1. Connect the JTAG output from the damaged device to JRT Adapter, or directly to SMTi box 2. Select CPU family type (3) 3. Select the type of CPU (4) and the device (5) if the repaired unit is not on the list, you must manually select the type of flash memory (6) 4. Connect the power supply to the repaired device and press POWER ON To connect the power adapter can be used with the measurement of power consumption, will see whether the CPU is able to work or not. You can also use the power derived from SMTi, in this case the CPU state can be made by measuring the voltage meter on one of the points: V-JTAG, V-TREF, V_MSMP, VPD, VREG_MSMP. In devices with two types of CPU (TYPE - PDA) should be given a separate power supply to the point PS_HOLD 2.6V, or a different value if it is given in the description of the JTAG pins.The PDA phones, it is important to attach the phone mode DOWNLOAD 5. Click on Check Connection (11), validate the connection and communication SMTi with the device. If it is OK. This dialog box, see Example - I8510 CPU MSM6281 Code: ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 ***************************************** 7. Click on the Write Boot (14), if the communication is OK. dialog box, see : Example - I8510 CPU MSM6281 Code: ***************************************** Write Boot: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 - MCP NAND ID: EC 76 - Chip: Samsung K9k1208d0c(u0a)/K9K1G08/ 512 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x20 pages - Page Size: 0x200 bytes - Total Page Size: 0x210 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:OEMSBL2 ...Success! - 0:OEMSBL1 ...Success! - 0:QCSBL ...Success! - 0:MIBIB ...Success! ***************************************** Solution to the problem of communication 1. When you try to check the connection Check Connection (11) shows only: Code: ***************************************** Check Connection: Target Not Found! ***************************************** b.) Check that by pressing the POWER ON on one of the checkpoints: (V-JTAG, V-TREF, V_MSMP, VPD, VREG_MSMP) occurs in line voltage the type of CPU (2.6V MSM.), or the power of the ammeter, if there is power consumption. If the voltage or power consumption occurs only when you press the Power On, hold the button and follow the Erase Boot (13) disconnect power and reconnect the device. Now press the Power On, select the Use the Start INIT (9) and press the Write Boot (14) 2. When you try to upload a new Boot Loader dialog box is displayed: Code: ***************************************** Write Boot: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 ***************************************** disconnect power and reconnect the device. Now press the Power On, select Use Start INIT (9) and press the Write Boot (14) 3. When you try to upload a new boot loader, or delete Boot'a displayed: Code: ***************************************** Erase Boot / Write Boot: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301C00E1 - MCP NAND ID: 00 00 - Chip: Unsupported! ***************************************** b.) Connect the power supply unit from SMTi, or JRT Adapter, select Auto Power (8) and press Erase Boot (13), the program will ask you to press and hold the Power On button naprawianym the device - to be confirmed to do this by clicking on "YES". If everything done correctly, the program will erase Boot'a. After this operation, disconnect power and reconnect the device. Now press the Power On, select the Use the Start INIT (9) and press the Write Boot (14) Note: Auto Power (8) does not work properly on phones with two CPUs (TYPE-PDA) Information about Read Boot option Read Boot: This function allows the Boot Loader to read from the device. With this option if you use: a.) to the device is not available to support members JRT Boot Loader recovery. b.) After uploading the Boot Loader recovery unit is still no communication USB to a computer, or have other problems with the device. Check support web for more JRT Activation Module costs 50 credits and is possible from within SMTi To activate a new module in the program SMTi the user must choose: 1. Select Module 2. JTAG REPAIR TOOL 3. Click ACTIVATE JRT and next OK After proper activation ACTIVATE JRT disappear, and your account will be charged 50 credits. From now on, you can take full advantage of the JTAG module Rrpair Tool. Boot Repair Has Never Been So Easy ! Just ... Click ... Click ... Only ! SMTi JTAG JRT - Join The Professionals !!! Best Regards SMTeam Last edited by gsminfo; 09-06-2010 at 08:15. |
The Following 33 Users Say Thank You to gsminfo For This Useful Post: |
03-31-2010, 19:19 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: TUNISIA Age: 44
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | @live14 For other Services maybe ! Even you can find cheaper with Standard comunication interface ! But For Special Jtag interface & with Exclusive Options include Updates & Support i don't think so it will cost you $$$ Vs 50credits |
03-31-2010, 19:31 | #12 (permalink) | |
No Life Poster Join Date: Jan 2008
Member: 673661 Status: Offline Thanks Meter: 349 | Quote:
unlock with creadi!!!!! repair with creadi!!!!! flash with creadi !!!!! no free feature why not ****activation**** for unlock all sagem for free | |
03-31-2010, 19:49 | #15 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | I've read carefully and I'm excited about this addon.Also I have ort and NoICE debugger but surelly I'll gone activate this addon on my dongle because I preffer more tools that are supporting the same features because each coder has it's own ideas and skils to implement this features in better and profesional ways like is in this addon for example. I'm using sagmaster products from the begining and I'm very pleased with them but what's about the jrt adapter?I saw there is an IC in it's design;what type is? the diagram schematic will be uploaded here to make us one or we must buy it? Not to forget:the price it's veryy good for this activation in comparation with other tools so I'm not complaing. I wish You Good Luck in this new project and many many dead boot repair with this tool for us. Best Regards! |
The Following 2 Users Say Thank You to Burebista For This Useful Post: |
SMTi Ver 18.75 - JRT Module Update. | gsminfo | SMTi JRT | 0 | 04-08-2010 10:46 |
SMTi Ver 18.75 - JRT Module Update. | gsminfo | Service Products News & Updates | 0 | 04-08-2010 10:43 |
SMTi JTAG REPAIR TOOL [JRT] Module Activation & SMTi Credits Added | NadeemShahzad | Gsmfather The Wholesale Unlocking Database | 0 | 04-07-2010 17:59 |
SMTi JTAG Repair Tool Ver 18.74 released - New models support added !!! | gsminfo | Service Products News & Updates | 0 | 04-07-2010 16:22 |
KKMC Ver 2.73 Released - LG BL-series free unlock added | gsminfo | Service Products News & Updates | 0 | 04-04-2010 09:02 |
