Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > ET-BoX
Old 02-15-2008, 09:25   #1 (permalink)
Member: 436006
15/02/08 : ET-BoX v1.59 Released - Repair IMEI for LG KG110, B2050 + Added 10 Models!
February 15th 2008 - v1.59 Released
Big Bang for LG Lovers!!
# Repair IMEI for LG KG110, B2000, B2050, etc. - {First Time for Indian Customers!!}
# Added Full Support for 10 New LG Models
# LG KG130, MG120, MG125, KG90, KG320, KG328, MG320, KG800, MG800 & TG800
Br.
ET-BoX Team
Mirror Link: http://www.et-box.net/ET-BOX_1_59.zip
Old 02-15-2008, 09:27   #2 (permalink)
Member: 436006
Procedure to repair IMEI on LG KG110, B2050, etc.:
1. Connect Phone
2. Press "Repair IMEI"
(If in case phone still have something wrong with IMEI, then full flash the phone and then again try to repair IMEI)
Br.
ET-BoX Team
Old 02-15-2008, 09:29   #3 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Some Basic Hints & Tips with LG KG110
1.
Problem: When try to make some phone call from LG KG110, then you get "Call Dropped"
Reason: Bad IMEI
Solution: Connect phone with ET-BoX v1.59 or above and Repair IMEI
2.
Problem: Phone restarts as soon as backlight goes off.
Reason: Mostly or you can say 100% is Hardware Problem
Solution: Check PCB for dry soldering or even try to reball Flash and CPU
3.
Problem: Phone hangs on main menu. (its Hang, not restart)
Reason: Bad Software Data
Solution: Flash the phone with fw_1 and fw_2. All should be OK
4.
Problem: You get on screen after sim "Service Not Available"
Reason: Damaged Eeprom
Solution: Connect phone with ET-BoX and press "Repair Service not Available"
Br.
Naman
Old 02-15-2008, 09:32   #4 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
I just had a LG B2050 with 00000 IMEI with me. Tested and working 100%
i will post screenshots with KG110 as soon as i get some.
Naman
Old 02-15-2008, 09:59   #5 (permalink)
roshantelecom&s's Avatar
Member: 368546
nice update thanks a lot sir ,i have 2 set with me i will make it then i will post it
Old 02-15-2008, 10:10   #6 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Great update thanks Et-Team
Old 02-15-2008, 11:47   #7 (permalink)
kalpeshoza's Avatar
Member: 462292
GREAT UPDATE FOR ET-BOX USER....................... BUT IF ET-BOX ADD THE BLUE 245X UNLOCKING IS THE BIG UPDATE FOR INDIA USER AND ET-BOX TEAM TOO.
THANKS
Old 02-15-2008, 12:47   #8 (permalink)
Member: 641836
nice update ...and great thank
good update.....pl..add chiense other model's cpu
Old 02-15-2008, 13:05   #9 (permalink)
irfanamin2's Avatar
Member: 82423
Good update thanks Et-Team.
Old 02-15-2008, 16:10   #10 (permalink)
Member: 169274
Very Good Update ......Thankx a LOT ET-BOX TEAM.
br.
Anchit
Old 02-15-2008, 18:26   #11 (permalink)
Member: 610974
real update
that is the real............. update thanks to et
Old 02-16-2008, 05:14   #12 (permalink)
Member: 455668
Now This A Great Update Et Team Thanks..
Old 02-16-2008, 05:31   #13 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks For The Update Keep It Up
Et-box Team
Old 02-16-2008, 07:22   #14 (permalink)
Sandeep Mobiles's Avatar
Member: 530721
Hello ET-BoX
Br.
ET-BoX Team
For KG110 IMEI repair u have taken long time I returne 2 mobiles any way thanks good update
Old 02-16-2008, 07:25   #15 (permalink)
Member: 68136
u can change imei with vygis
25/10/08 : ET-BoX v1.75 Released - Diwali Gift for ET Customers : Chinesse Infenion ! nonu_don ET-BoX 26 11-10-2008 06:05
25/10/08 : ET-BoX v1.75 Released - Diwali Gift for ET Customers : Chinesse Infenion ! rotelcam GSM News & Updates 0 10-27-2008 23:19
29/04/08 : ET-BoX v1.64 Released - Added Support for LG KP200 & KP202 .:ET-BoX.net:. ET-BoX 16 04-30-2008 12:18
12/02/08 : ET-BoX v1.58 Released - Added Airtel FGD9000, ZTE A12 & Samsung C260m C266 .:ET-BoX.net:. ET-BoX 11 02-16-2008 05:33
05/02/08 : ET-BoX v1.57 Released - Added Spice S535 & New Flash ID for Chinesse MTK .:ET-BoX.net:. ET-BoX 15 02-10-2008 06:28
Page generated in 0.38750 seconds with 11 queries
