01-22-2010, 18:31 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Sir, please use this manual : http://www.et-box.org/ET_ChinaTool.pdf if any problems, then please do let me know about it, i will try to help you out. Br. Naman |
01-23-2010, 06:15 | #4 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | hi nonu as in manual i tried to repair the imei number, but everytime it says " tip: the imei is a 15 digit code" . I have filled both imei with new and old imei respectively and both are 15 digits. I have given path for old read file. Now what to do |
01-23-2010, 06:49 | #5 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Procedure to Repair IMEI on Spreadtrup CPU with ET-BoX Plus:
01-23-2010, 06:54 | #6 (permalink) |
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | i hope the instructions are very clear, the procedure is totally different from what we use in MTK CPU. but is very easy. let me explain you again as best i can. 1st u need to take full backup of the flashfile of the handset for which you want to repair the IMEI. means you need to read the flash file of this handset and save somewhere in your hard disk. now, go to spreadtrum tab, select IMEI, and enter the IMEI which is in the handset in the "Original IMEI" field and the new IMEI which u want to put in the handset in the "New IMEI Code" field. Now click the "..." to select the flash file which you read in the previous step. and then click start. the software will make a new flash file with new IMEI name in the same folder where you put the original readed flash file. now this new flash file has the new IMEI which u desired. you can just flash it to the phone and your phone will have the new and repaired IMEI. Please let me know if u still have some problem. i will try to help you again as much as i can. Br. Naman |
what's the matter with spread trum processor,? | fessi | Infinity-Box | 0 | 06-13-2009 14:29 |
plz support helpme d2000 spread trum | goldenploto | SpiderMan | 2 | 03-16-2009 18:53 |
spiderman plz.check the spread problem in fomatting | rajesh_ch | SpiderMan | 6 | 09-08-2008 03:39 |
c1000 spread trum ship plz help | melgsm | MC-Tool | 3 | 03-10-2008 13:53 |
Current Supported Models in ET-BoX as Of April 11th 2007 | .:ET-BoX.net:. | ET-BoX | 4 | 04-17-2007 08:52 |
