Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > ET-BoX
Old 01-22-2010, 15:07   #1 (permalink)
narendra22's Avatar
Member: 1102971
Sonork: 100.1611545
spread trum in et
spread trum in et please help any manual pdf please help
how to use
Old 01-22-2010, 17:31   #2 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Sir, please use this manual : http://www.et-box.org/ET_ChinaTool.pdf
if any problems, then please do let me know about it, i will try to help you out.
Br.
Naman
Old 01-23-2010, 04:35   #3 (permalink)
narendra22's Avatar
Member: 1102971
Sonork: 100.1611545
Arrow please help
please see screen shot how to use
http://www.4shared.com/file/20473409...df/etplus.html
Old 01-23-2010, 05:15   #4 (permalink)
bhuvanele's Avatar
Member: 237210
hi nonu
as in manual i tried to repair the imei number, but everytime it says " tip: the imei is a 15 digit code" . I have filled both imei with new and old imei respectively and both are 15 digits. I have given path for old read file.
Now what to do
Old 01-23-2010, 05:49   #5 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Procedure to Repair IMEI on Spreadtrup CPU with ET-BoX Plus:
  1. Take full backup of handset using the “Readback” feature.
  2. Go to “SpreadTrum” tab, select “IMEI”, enter the new IMEI in “New IMEI Code” box and the existing IMEI in the handset in “Original IMEI” box.
  3. Select the readed flash file in step 1 in the file location and then press “Start”.
  4. Now a new file has been created in the same folder with new name ending with new IMEI. Just flash this new file to the handset using the “Download” feature.
  5. Your phone now has the new and repaired IMEI.
Old 01-23-2010, 05:54   #6 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
i hope the instructions are very clear, the procedure is totally different from what we use in MTK CPU. but is very easy. let me explain you again as best i can.
1st u need to take full backup of the flashfile of the handset for which you want to repair the IMEI. means you need to read the flash file of this handset and save somewhere in your hard disk.
now, go to spreadtrum tab, select IMEI, and enter the IMEI which is in the handset in the "Original IMEI" field and the new IMEI which u want to put in the handset in the "New IMEI Code" field. Now click the "..." to select the flash file which you read in the previous step. and then click start.
the software will make a new flash file with new IMEI name in the same folder where you put the original readed flash file. now this new flash file has the new IMEI which u desired. you can just flash it to the phone and your phone will have the new and repaired IMEI.
Please let me know if u still have some problem. i will try to help you again as much as i can.
Br.
Naman
Old 01-23-2010, 13:52   #7 (permalink)
narendra22's Avatar
Member: 1102971
Sonork: 100.1611545
Thumbs down thanks
very good
thanks
sir thanks
thanks
Old 07-26-2010, 14:18   #8 (permalink)
Member: 283274
Link not workinggggggg
Old 08-01-2010, 20:26   #9 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
can u please cheak again,, which link not working?
Br.
Naman
what's the matter with spread trum processor,? fessi Chinese Miracle & PinFinder 0 06-13-2009 14:29
plz support helpme d2000 spread trum goldenploto SpiderMan 2 03-16-2009 18:53
spiderman plz.check the spread problem in fomatting rajesh_ch SpiderMan 6 09-08-2008 03:39
c1000 spread trum ship plz help melgsm MC-Tool 3 03-10-2008 13:53
Current Supported Models in ET-BoX as Of April 11th 2007 .:ET-BoX.net:. ET-BoX 4 04-17-2007 08:52
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.29418 seconds with 8 queries
