Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 01-12-2011, 06:39   #1 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
Thumbs up Bga pad repair
Hi all,, as we see there are many thread discussing about bga chip and solutions, in this opportunity i'm trying to post a new topic " BGA PAD PEPAIR " anybody with your experiences, ideas or solutions would please to share with us...Have a nice day
example pic :
Old 01-12-2011, 11:13   #2 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
example pic :
Hello,
BGA PAD repair requires good soldering skills and most important is steady hand, very good eye sight or you have to use very good quality lens (magnifier), buy a good quality solder gun with temp controller (should support lead free) with fine soldering tip, some lead free solder wire, copper de-soldering wick and a blade.
BGA PAD repair requires time and attention, some pads are dummy on the pad so need not worry if it has come out, some bga pads will be test points so no need to worry about it, but check for the pads which are important excluding the other two i have mentioned earlier, once the pads are noted for reconstruction, take the blade remove the conformal coating till the pth point or till it has broken and first solder copper de-solder wick strand to the end where the bga pad line is broken, then route copper wick strand to the bga pad where it will come into contact with bga ic solder ball , cut the strand using a blade. use lead free solder for bga contruction because if you use lead based solder the melting point is 183 deg and if the bga ic you are replacing is lead free (215-220 deg) chances are the copper strand you have used for reconstruction of the pad will move.
if possible will post photos of reconstructed pads.
bye
The Following 2 Users Say Thank You to pentu For This Useful Post:
Old 01-12-2011, 12:37   #3 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
Thumbs up bga pad repair
Woow,..thank a lot for your great ideas on how to repair bga pads..seems Mr.Pentu is having many experiences in bga repair section..really hope you can share more about it..it would more clearly and exiting if you can put some pics on how you use de-soldering wick to rebuilt a missing bga pads as the picture i showed above..
Mr.Pentu do u know each bga pad on board has it function or not? or some just stand on hole and act like a ground.i see some just stand alone on hole without a wire joinned from board, but mostly are jointed as we can see..
thank for your time to share with us..
Old 01-26-2011, 12:52   #4 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
anybody has more exiting experiences in repairing bga pads? please share, thx...
Old 01-27-2011, 19:42   #5 (permalink)
Member: 44625
Thanks Meter: 36
Pentu and his team are expert in pad repairs. To know which pads are needed and which are not, find the chip's pinout diagram and you'll know which pins are connected to ground, which are test points and which are essential for the functioning of the chip.
B.R.
Old 01-31-2011, 15:04   #6 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
i want to post the photo of pad repair but when i upload it says upload fail
Old 02-01-2011, 06:34   #7 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
hi Mr.Pentu
you may try to upload again..maybe the server is busy or the line is going down when you upload it,,never mind pls try again...
anyway last night i was trying to clean another acer aspire 4520 bga pads for reball, as usual i put a little flux first, then set solder tip for about 350-400 C to swipe all solder balls on pad slowly,.after that i use "BAKKU" solder wick to clean the lefted solder balls carefully on pad,,
i used to clean it from right side to left for whole pads, until now i still hv a problem to fix it well, i can see some pads will be lefted ( take off by solder wick ) when i cleaned it, i hv run it slowly and carefully but some pads still going to lefted,,
all i want to know is..am i using a wrong solder wick or having a wrong direction to clean the pads?any tips for this pls guide me to the right way for doing this better as i hv tried for more than 10pcs of bga pad on boards and all with fails...
thank you...
Old 02-01-2011, 09:14   #8 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
hi Mr.Pentu
thank you...
Remove excess solder directly with the solder tip and then apply tiny amount of flux to the wick and use it to remove solder, dont try to cover large area at a single time.
Pad re-work photo
The Following 3 Users Say Thank You to pentu For This Useful Post:
Old 02-01-2011, 09:20   #9 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Pad re-work photo
For this type of repair you could use with success any sylver / graphite solution to redraw the print http://www.e-piese.ro/components/com...3a9b433d92.jpg
WBR,
gsm9l
The Following User Says Thank You to gsm9l For This Useful Post:
Old 02-01-2011, 09:21   #10 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
After the IC is Placed
Old 02-01-2011, 10:13   #11 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
WBR,
gsm9l
thanks for the suggestion, but they have specified temp tolerance of -60 degree to 120 degree in the catalogue, in BGA rework it exceeds well beyond these temperatures
thanks
Old 02-01-2011, 10:17   #12 (permalink)
Crazy Poster
Member: 473301
Thanks Meter: 11
halim XU for Acer 4520 give bottom temp more than what use for other boards
bye
Old 02-02-2011, 06:31   #13 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
bye
Hi,Mr.Pentu
alright i'll try it for nxt board, now still learning to clean bga pads well to make sure no any pads lefted again..thank for your great suggestion..bye
Old 02-28-2011, 23:24   #14 (permalink)
Member: 1285693
Thanks Meter: 5
Hi Pentu, thats some good quality work you have done.
Old 03-09-2011, 13:06   #15 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
Thanks Meter: 3
Hi All,
I just trying to clean a v3000 bga pads ,again one of the bga pad lefted when i clean it with solder wick, but i can see the pad has no connection line with others / just stand alone on hole , is it has a function or not? is it fine if i just put some glue to fix it back on hole,,or anybody has v3000 bga scematic for make sure the fuction for each bga pads
please help..thanx
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 10-04-2011 05:45
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
Contact Service Repairer 1.2 by Bartek Allen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-23-2011 09:00
5110 Contact Service Repairer via MBUS/FBUS Allen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 11-15-2010 04:17
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Main Sales Section 0 01-02-2001 10:12
Page generated in 0.22689 seconds with 9 queries
