RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
06-28-2010, 16:18 | #18 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437621 Status: Offline Thanks Meter: 19 | New question: Anyone know a reliable source for the NF-G6150-N-A2 BGA's I am getting very frustrated with the Chinese sending me reballs when they sell as new. I have lost a lot of money sending 5 lots back because of this. I can't find new product anymore that I can trust . They are real slick too reusing factory packaging and grouping date codes, but the signs of reballing cannot hide from a video microscope. With a reball you can see many signs of solder removal in the form of scratches and residue. This does not exist when the chips are actually new. I am sorry, Chinese reballs are junk. I tried them and get a 50% yield on them and the failure rate is high when they do work. I am better off reflowing then wasting my money on buying the Chinese junk. Oh, can't blame it all on the Chinese. One lot was from Canada, but he got them from China. Yeah, I know that is when they are produced and factory stocked. Can anyone help me out here? |
06-28-2010, 18:37 | #19 (permalink) |
Crazy Poster Join Date: Mar 2007
Member: 473301 Status: Offline Thanks Meter: 11 | Dan, i am buying with few suppliers (indians staying in china) from china till recently i got new G6150-N-A2 chips but they say new chips are not available now, they offered me '09' year code dated reballed chips, i got the stock today 50 nos it looks neat and good, i have sent 25 nos to my client i will get feed back within couple of days, i will post the results. you can also try with Taiwan suppliers, but high price and purchase quantity should be more. thanks |
06-30-2010, 19:16 | #20 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | I also bought reballed 09 date code chips. Gone through 30 of them and only 2 worked. As soon as you get to 220C they blister. I think too much heat was applied during the reball process and destroyed the chips. That is the problem when buying reballed chips. You are trusting that the reball process was done correctly. Usually I bet not. They only care if the chips look good, not if they actually work. If they reballed them using leaded solder, I would probably have had less of an issue with them. So you say the Taiwan sources are more trustworthy. I also see G6150 sellers from Hong Kong. Anyone had luck with those suppliers? |
07-01-2010, 09:37 | #21 (permalink) | |
Freak Poster Join Date: Dec 2001 Location: Shenzhen, China
Member: 7911 Status: Offline Thanks Meter: 7 | . Quote:
07-02-2010, 17:02 | #22 (permalink) |
Junior Member Join Date: Mar 2005 Age: 52
Member: 132074 Status: Offline Thanks Meter: 13 | hi, i bougt 10 pcs of g6150 datacode 09, new ones... from this guy: 10pcs New nVIDIA BGA IC Chipset NF G6150 N A2 Date 09+ su eBay.it Electronic Components, Electrical Test Equipment, Business Industrial this was almost 3 months ago, i used them all and, i got 100% working, and zero return. in the same period i bought also 15 spp100 nvidia bga datacode 06, selled has new but they was reballed, from another seller. on this lot i had few problems, but they where accepptable... 100% working, and about 3 returns. in my experience i can say that reballed chips can be good... or bad.. it depends by the seller. some seller sells true reballed chip, not cominig from deads motherboards, and generally with these ones the results are good, very few returns, about 10%. others sells very cheap junk... if you want real new ones, start from asking datacode 09... every earliers datacodes are not new...no way, and yes, it can't be else, as it would be very very economically strange that a 06 or 07 chip would stay in stock until 2010... nvidia spp100 datacode 09 are very hard to find...i'm managing to have some of these, but i will tell to you more in the next days... and, last thing, i alaways reball with leaded balls. even the new ones. soldering lead free with jovy it is not safely possibile, at my opinion. lead free reliable bga soldering is not a joke.. |
07-29-2010, 19:33 | #23 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | NEW question. When replacing lead free solder balls with leaded, wouldn't there be an issue with the lead free solder coating on the pads turning liquidus at the lower temperatures creating a barrier between the leaded solder ball and the pad? Maybe we should apply some leaded solder to a wick and pass it over the pads to blend the solders first. Seems that the lead free solder coat on the pad may not turn totally liquid at leaded temperatures. And the whole point of using the leaded is so we can use lower temperatures to protect the devices and circuit board. Any thoughts on this? Dan |
07-30-2010, 10:49 | #24 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 301521 Status: Offline Thanks Meter: 12 | hi, very cool thread. i have dv6000 board. i changed gf-7200 chipset to 7400 not worked? and i have question: can i change nf-spp100-n-a2 to 6100 or 6150? i have a board on it nq82910gml chipset. i can not found that chipset.. i bought nq82915gm chipset can i change i910 to i915? will work? thanks a lot for answers |
08-01-2010, 17:38 | #28 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | There are other changes to do if you want to remove GO7200 and use G6150 as video. Never tried replacing SPP100 with G6150. This would be good to know this info if anyone has had success with this. The motherboard BIOS may be a factor in the choice of video chips. I do know that the motherboard circuits are identical with different video layouts, but there are other component changes as well, resistors and caps. Much effort in doing this. Really not worth the time for me. TriMesh - I am still waiting for my test socket. It is expected very soon. Had to have it custom built. I will post pictures as soon as I have it setup. |
08-06-2010, 22:13 | #30 (permalink) |
Member: 301521 Status: Offline Thanks Meter: 12 | que my another problem: i have vgn-fs215 motherboard. tested cpu and rams with another board. the problem is, motherboard not power on. i measured 8v power button. everythink lookslike fine. no shortcircuit on board components. i make some hotair to hn82801fb (sl89k) doesnt matter. i know this is sony's classic problem. but i can not find problem yet. i will rework on that board but please tell me your idea be4 working on it. what do u think about this problem? |
Questions about Dejan's flasher interface | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 01-15-2001 09:31 |
8890 questions | spongebob | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 01:04 |
Pragramming 5110 - 24c16 chip | xPumpa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-21-2000 23:28 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
