RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
05-31-2011, 09:01 | #91 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 301521 Status: Offline Thanks Meter: 12 | hi changed u21 (ics). but its warm up too hot. can put my finger 5 sec. any idea? |
05-31-2011, 13:38 | #92 (permalink) | |
Crazy Poster Join Date: Mar 2007
Member: 473301 Status: Offline Thanks Meter: 11 | Quote:
06-03-2011, 09:43 | #93 (permalink) | |
Member: 301521 Status: Offline Thanks Meter: 12 | hi Quote:
i can change chipsets like changing socket cpu's recently i changed and reballed a 965 chipset as 20 times. no problem. its like cpu. i know all temperature degrees. i use my hand made rework machine. you can search youtube 'change bga 4 minutes' ... i need to say; its right its bridge. did you ever check a dv6000 board by removing gpu and test like it ? now, i am also a human and i can make mistakes. in this reason i am asking questions need to now ideas. and thanks for answers. i found that board 945, gpu and also all components has no problem. its short circuit between board layers. removed all components and put other bad board. now its working.. have some problems like no sound and not charge etc.. but board working, just testing board. have a nice day. atombilgisayar | |
06-06-2011, 17:13 | #96 (permalink) |
Member: 301521 Status: Offline Thanks Meter: 12 | hi dan, that video quite old. now i can change chipsets in just 2 min's. its so simple for me. i will upload new video with high quality when i will be free. then you can check resistors and caps. |
06-07-2011, 15:27 | #97 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437621 Status: Offline Thanks Meter: 19 | Personally I have never been successful using hot air. Always moving nearby components. Thats why I switched to IR. But if you did it using a handheld IR unit, that may work better for me. The one thing that bothers me about this approach is how do you control the upper heat limit. Seems to me that approach would apply too much heat to the device unless you had a lot of practice and patience, just like working with the Jovy. If the Jovy had larger lower heaters it would be just as effective. Another issue I have is you cannot make the ramp time too short or that could also damage the device. But I bet you compensate for that by appling most of the heat to the lower side of the board thus saving the BGA from too much heat. The real secret is to heat the entire board so it has equal heat distribution, but get it too hot and the heavy components will fall off and the connectors will melt. Use too much reflective tape and you stop the whole board from heating evenly. Quite a challenge I must say. |
01-19-2012, 09:41 | #99 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1461747 Status: Offline Thanks Meter: 0 | Hello, i have a pavilion dv9000 with intel cpu. The board power up for a second and shuts down immediately (no reboot, it remains off). Can this happen due a faulty gpu? Thank you! |
01-20-2012, 10:33 | #101 (permalink) |
Junior Member Join Date: Dec 2006
Member: 413017 Status: Offline Thanks Meter: 1 | Yes I have seen this before and turned out to be GPU. Just listen out to any clicking or shorting just in case it is a power IC. |
The Following User Says Thank You to ian8115 For This Useful Post: |
01-29-2012, 02:11 | #103 (permalink) |
Member: 301521 Status: Offline Thanks Meter: 12 | dv6/7 liverpool i have dv6-3110st. my brother erased u21 (ecrom 4mbit flashrom) instead of bios. i need urgent ecrom dump or ec.rom file. orginal and lastest bios image is sp55299.exe. already thanks 4 all... |
02-15-2012, 13:20 | #104 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1716357 Status: Offline Thanks Meter: 0 | Yes definitely I have had this. It was caused by a short on the 1.2 volt rail, I removed all the caps and the short remained. I finally got the GPU off and no short anymore and the board fires up. I always check for shorts from ground to the inductors, if you find a short it is simply a matter of referring to the schematic to see which rail and what is connected to it. |
02-27-2012, 08:09 | #105 (permalink) |
Member: 301521 Status: Offline Thanks Meter: 12 | dv6 i found ec rom into bios imagee extracted successfull. if anyone need i can send. Now i have problem with clevo's w765s before a month i change ite8502e for 3 led flashing (like overheating) problem fixed succesfull. i have 2 pcs machine now cant fix with change ite. same issue occurs. i changed thermal ic (u7), clock generator (u15), some thermal resistors. still same. flashed lastest bios from clevo's ftp. also flash new ecrom but still same. notebook does not overheating. i measure all places temperatures are normal. also change cpu different mhz still same. have idea? |
Questions about Dejan's flasher interface | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 01-15-2001 09:31 |
8890 questions | spongebob | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 01:04 |
Pragramming 5110 - 24c16 chip | xPumpa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-21-2000 23:28 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
