Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 03-19-2012, 07:35   #106 (permalink)
Member: 1736325
g86-703 - g86-721 - g86-730 interchangeable
Old 03-19-2012, 19:45   #107 (permalink)
Member: 1736325
adding video ram to DV6000 / DV9000
Could it be possible to add more video ram to HP DV6000 / DV9000 by changing the following pairs of resistors:
R133-R102 (RAM_CFG0)
R620-R621 (RAM_CFG1)
R132-R104 (RAM_CFG2)
R101-R103 (RAM_CFG3)
They define 4 bits that are interpretted like this:
- for 64 bit NB8X
0000 - 16Mx16x4, 64bit, 128MB - Elpida
0001 - 16Mx16x4, 64bit, 128MB - Samsung
0010 - 16Mx16x4, 64bit, 128MB - Infineon
0011 - 16Mx16x4, 64bit, 128MB - Hynix
0101 - 32Mx16x4, 64bit, 256MB - Samsung
0110 - 32Mx16x4, 64bit, 256MB - Infineon
0111 - 32Mx16x4, 64bit, 256MB - Hynix
1000 - 16Mx16x2, 32bit, 64MB - Elpida
1001 - 16Mx16x2, 32bit, 64MB - Samsung
1010 - 16Mx16x2, 32bit, 64MB - Infineon
1011 - 16Mx16x2, 32bit, 64MB - Hynix
- for 128 bit NB8X
0000 - 16Mx16x8, 128bit, 256MB - Elpida
0001 - 16Mx16x8, 128bit, 256MB - Samsung
0010 - 16Mx16x8, 128bit, 256MB - Infineon
0011 - 16Mx16x8, 128bit, 256MB - Hynix
0101 - 32Mx16x8, 128bit, 512MB - Samsung
0110 - 32Mx16x8, 128bit, 512MB - Infineon
0111 - 32Mx16x8, 128bit, 512MB - Hynix
1000 - 16Mx16x4, 64bit, 128MB - Elpida
1001 - 16Mx16x4, 64bit, 128MB - Samsung
1010 - 16Mx16x4, 64bit, 128MB - Infineon
1011 - 16Mx16x4, 64bit, 128MB - Hynix
1101 - 32Mx16x4, 64bit, 256MB - Samsung
1110 - 32Mx16x4, 64bit, 256MB - Infineon
1111 - 32Mx16x4, 64bit, 256MB - Hynix
Old 03-21-2012, 15:05   #108 (permalink)
Moderator
Member: 437621
As long as the correct componets are used, you should be able to increase memory. Also requires a discrete GPU is used. Wont work with 6150/7150
Old 03-21-2012, 15:07   #109 (permalink)
Moderator
Member: 437621
Anyone know if AMD/ATI Radeon parts 216-0674022 0674024 0674026 are interchangeable?
The 216-0674026 is easier to find in new late date codes.
Old 06-04-2012, 15:23   #110 (permalink)
Member: 301521
i will try it if i got a mobo, then turn back to you
Old 06-04-2012, 15:25   #111 (permalink)
Alkapone's Avatar
Member: 19265
They are interchangeable to higher number - 022 to 026, 024 to 026.
B.R.
Alkapone
Old 06-04-2012, 15:27   #112 (permalink)
Member: 301521
- for 64 bit NB8X
- for 128 bit NB8X
yes, you can but only g86-770-a2 or 7600-a2 chipsets needed. otherwise you need to write a new bios. in the reason its hard to be possible
Old 06-20-2012, 01:09   #113 (permalink)
Moderator
Member: 437621
New question
Anyone familar with KB3926QF
Seems there is a code after the part number. ie A1, C0, D2
Do these codes matter? I tried replacing a Code C0 with a code A1 and had issues.
Anyone have a datasheet on this controller chip? Used on a lot of motherboards.
Old 06-25-2012, 22:39   #114 (permalink)
Member: 301521
New question
I couldn't find a datasheet for directly for chips. But I believe you can find datasheets on motherboard schematics.
Nevertheless it matters cuz they're different chips. I tried before they're not interchangeable (just for ene)
Winbonds 773ldg and 775ldg are interchangeable(773 may not be ldg; but I know 773 and 775 are interchangeable for winbond).
Good luck...
Old 06-27-2012, 16:53   #115 (permalink)
Moderator
Member: 437621
I can confirm that the codes do matter. If you are replacing this chip. Use the same code
Old 07-22-2012, 12:34   #116 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
solder ball and paste expired
hi all,
anyone know is there any problem/risk after using an expired solderball and paste?and what is the effect after using the expired solder ball and paste for reballing?will it cause the solderball on chip will not attached corectly to board/bga pad when soldering process?
thank you
Old 07-23-2012, 05:09   #117 (permalink)
Crazy Poster
Member: 1481034
Sonork: Halim_Xu
expired solder ball and solder paste
Hi all,
any body know what's the effect of using the expired solderball and paste?
as we can see there is manufacture date attach on bottle, and giving a validity for one year..i have some with 2010 manufacture date.
any idea about this please..
thank you
Old 07-23-2012, 20:33   #118 (permalink)
Moderator
Member: 437621
I never had an issue with expired solder. Some of my solder balls are 3+ years old and they work fine. I do keep them in a sealed container. I think the flux is more important not to be too old. Metal stays metal, as long as it doesn't oxidize, but the chemicals in flux change over time.
Old 08-11-2012, 09:36   #119 (permalink)
Member: 301521
hi
did anybody try ac82gm45 instead of ac82pm45 with external graphics chipset on motherboard (i mean motherboard has external graphics chipset ati)
i saw many motherboard has external graphic chipset with ac82gm45
for now i have a ac82pm45 with external graphics chipset but i have not a pm chip. i have many gm's...
thanx in advance.
Old 09-08-2012, 09:11   #120 (permalink)
Member: 301521
is le88clgm same as gm965?
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 01-10-2001 00:04
Pragramming 5110 - 24c16 chip xPumpa Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 11-21-2000 22:28
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-06-1999 23:47
Page generated in 0.26311 seconds with 11 queries
