Unlock Server
Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 01-01-2010, 11:33   #1 (permalink)
Member: 1083488
Question diameter balls
hello i want to know the diameter of the ball was put on a BGA NIVIDIA G86-750-A2 is it 0.50 or 0.60 ?
thank you for your help
Old 01-10-2010, 10:19   #2 (permalink)
Member: 7062
Each package has a tolerance of +/- .10mm allowed , you can refer to the package information in the data sheet .
Or, if you sure of remove all teh old solder material from the package and the PCB pads you can use 0.60 mm , if you not sure use small diameter balls.
BR//
Raheeeb
Old 01-10-2010, 19:49   #3 (permalink)
Member: 132074
reply
you have to use 0.6 diameter balls
Old 01-12-2010, 19:17   #4 (permalink)
Member: 1083488
many thanks for your help
I need BGA IC ball making MACHINE DrMobile Hardware Repair Item Wanted 5 09-08-2005 21:18
Balls to replace cobra ali-g-string Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 08-29-2002 10:32
Repair broken COBBA balls. Best solution needed. Chuk Nokia Hardware & Hardware-Repair Area 14 12-25-2001 03:10
Repair broken COBBA balls. Best solution needed. Chuk Nokia Hardware & Hardware-Repair Area 0 12-18-2001 08:43
Don't use cannon ball to kill mosquito Alf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-01-2001 17:31
Page generated in 0.30562 seconds with 12 queries
