RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
04-03-2010, 12:57 | #121 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Quote:
One thing to add to this Xbox360 RROD is that i am fixing them by just removing the x clamps with and use bolts loaded with spring washers on one side and 2 precise washers on each bolt on the other side. No need for expensive devices or tools. I thought it was going to be temporarily but in fact the oldest one has already been more than 6 months and going. If the RROD appears again.. just leave it to heat up (bolts just tightened by hand) for 20 minutes or when 2 red lights show up (whichever is first), leave to cool for 30 mins. Then tighten the bolts (of the GPU) if the system is ok (which normally is ok). | |
04-03-2010, 19:24 | #122 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1260631 Status: Offline Sonork: ddcmonx Thanks Meter: 1 | i'm new with jovy re 7500.. need help step by step cause i always make a bubble- ing mother board or the gpu ic .. i've tried in xbox 360 & ps3s.. help this jovy is killing me softly... |
04-05-2010, 07:14 | #123 (permalink) |
Member: 1262869 Status: Offline Thanks Meter: 1 | work with jovy I work with jovy and I repair 3 xbox,2 laptops just like raheeb says,before repair xbox I broken 3 xbox but I learn. need to use a kapton tape,and the flux,take a look to forum you found the profile to reflow xbox,posted by raheeeb. best regards |
The Following User Says Thank You to procesoare For This Useful Post: |
04-18-2010, 12:14 | #124 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1286153 Status: Offline Thanks Meter: 1 | repalce x-clamps hi , Im new here after reflow on jovy do you put the x-clamps back on or do you use the x-clamp repair screws... many thanks pid |
The Following User Says Thank You to pidster For This Useful Post: |
04-18-2010, 18:01 | #125 (permalink) | |
Eventually Jovy or not .... the design is flawed and the RROD will return one day or another. The best way is to increase the air flow and ventilation with extra fans on the top and sides. Preferably use also a heat sensor which will automatically increase the fans speeds to adjust the temperature inside. | |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
06-03-2010, 06:29 | #126 (permalink) | |
Member: 1257927 Status: Offline Thanks Meter: 3 | Quote:
For my success with this machine i have to say it is amazing. I have repaired a couple hundred xbox's, comps, and ps3s with this machine the last 4 months and i have not had a single return. This is especially good with the xbox 360s, all of the 360s that i fixed that were not touched before were repaired and had the x clamps put back on. Even previously repaired xboxs that had screws were repaired/reballed with the exception of two that were just too badly damaged. The machine works wonders as long as you know how to use it. | |
The Following 2 Users Say Thank You to blklightning21 For This Useful Post: |
06-06-2010, 19:06 | #128 (permalink) | |
Member: 1260631 Status: Offline Sonork: ddcmonx Thanks Meter: 1 | need guide Quote:
please give guide step by step using this jovy ... thnx alot have you try to reball any gpu? if you do post youre process here.. | |
07-23-2010, 16:11 | #129 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | |
The Following User Says Thank You to Nurettin Duman For This Useful Post: |
08-19-2010, 18:55 | #130 (permalink) | |
Insane Poster Join Date: May 2009 Location: unknown planet
Member: 1033535 Status: Offline Thanks Meter: 24 | Quote:
08-22-2010, 21:41 | #132 (permalink) |
Member: 1033535 Status: Offline Thanks Meter: 24 | Hello every body !!! i need some one ho can Fix XBOX360 ring of death i have my xbox360 has that problem !! if there is some can do that please tell me i am ready too pay and to ship it to any country !!! |
Tutorial of Remove Glued rap and flash chip by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 39 | 02-26-2009 11:33 |
PLEASE HELP! NEED MY K850i FLASHED - GOT THE BLUE RING OF DEATH 'BROD' BUG! | vickylee2008 | KULANKENDI Server | 5 | 04-28-2008 14:18 |
Tutorial of de-soldring by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 4 | 06-25-2007 00:48 |
killed 3 fones with re 7500 | farry | RE-7500 Reworking System & iSolder | 5 | 05-03-2007 22:28 |
didnt able to fix white screen of W850 with infinity SE-DB2020 client | Softway | Infinity-Box | 5 | 04-22-2007 11:09 |
