Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
| | #16 (permalink) |
| Junior Member Join Date: Mar 2010
Member: 1260631 Status: Offline Sonork: ddcmonx Thanks: 6
| re7500 will do fine for 43mm chip i did xbox reball / replacement gpu, also ps3 chip.. my re 7500 work just fine.. check it out : Desoldering Rsx ( SEM 001 ) with my JOVY RE7500 - YouTube |
| | #17 (permalink) |
| Junior Member Join Date: Feb 2010
Member: 1228446 Status: Offline Thanks: 3
| Hello i recently purchased this machine and for some reason the machine doesnt get to the temp i need. i am located in new york and work on iphone repairs and the desired temp is around 450-470 degrees f and for some reason the machine wont pass 400f. i was wondering if the problem might be that i am using a step up step down transformer because the machne is a 220 and i only have a 110. basically what i do i do the warm up stage until the machine gets to 200 and then i put uh and lh in fast reflow and then wait. it never makes it to 450f. any advise will help.. thanks |
| | #18 (permalink) |
| Moderator ![]() Join Date: Jan 2007
Member: 437621 Status: Offline Thanks: 6
| therepaircenter- You actually need a step-up transformer at least 2kw for the RE7500. If you still cannot get the desired temps, try bringing the board closer to the lower heater. I have adjustable legs on by board holder and typically have the board 3/4" to 1" from the glass. The upper heater is typically set to 2.5 to 3. |
| | #19 (permalink) |
| Thanks Dan, Quick question when you say 2.5 to 3 i dont have that option i only have preheat reflow and fast reflow. is it possible that i am doing something wrong.. ill tell you esxactly what im doing and you let me know what you think. i preheat the lower heater on park mode until it reaches 200 then i put the board on the adjustable legs and i make sure the board is as close as possible to the heat "less then an inch" and then i put the machine on fast reflow upper heater and fast reflow on lower and it barely makes it to 400. |
| | #20 (permalink) |
| First off, refer to Celesus, not Farenheit. 2.5 to 3 refers to the height markings on the upper heater shaft. I would preheat the board with the lower heater to 130C-leaded, 150C-LeadFree. Fast reflow on upper until 200C then Reflow, off at 215C. Let sit at 217C-235C for 20-25 seconds. (185C-235C leaded) The goal is to let the BGA dwell at 217C-230C for 20-25 sec. Do not go over 235C. I use a software stopwatch to insure dwell time. You must insure your heaters are off to not go over temp. I slide a copper plate over the lower heater and swing the upper heater as soon as dwell time is over. This drops the temps quicker for a better solder bond. Fan on at 160C-170C. Remove board at 75C The other thing to watch out for is that you stay in this temp range on both sides next to the BGA. Use 2 TC's. When the BGA is close to the edge, that side will heat up faster. If you go over 240C, throw away the BGA, it is cooked. Also, to avoid popcorning, you need to bake the parts for 125C for 48 hours before using. This is real important in a humid climate. Follow this for a 99% success rate. Last edited by Dan Collins; 04-27-2012 at 00:02. |
| The Following User Says Thank You to Dan Collins For This Useful Post: |
| | #21 (permalink) |
| Junior Member Join Date: Nov 2008
Member: 911468 Status: Offline Thanks: 0
| hello guys heloo guys i have the same problem on jovy RE-8500. ps3 not soaking on 207c -217c-220c. but the RSX SOAKING ON 236C ; i don't know what is problem i tried 4 board but the same results . i'm using the machine like that: PREHEATING UH 50 MH 100 SH 60 until 140c REFLOW UH 90 MH 60 SH 40 I removed the chip on 236 and reballed but YLOD not solved. please help ................ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 12-12-2012 12:26 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
