RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
03-25-2007, 08:51 | #1 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | Jovy Systems RE-7500 usage tips Since a number of us have got this infrared rework station, and have used it for a while, its time for us to share info on its usage. The moderators were supposed to start a separate section for this, but i feel they're very busy with the site and their work. So i have started this thread and am looking forward to the users giving us their tips and perhaps uploading some profiles they have made for the machine. If the moderators wish, they're free to move this thread to another section. I request members not to use this thread for things not related to RE-7500 usage. Please start sharing from today! Best regards, Trion |
03-25-2007, 21:20 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | @Trion (The moderators were supposed to start a separate section for this, ) Support section already opend so redirection of post done. (but i feel they're very busy with the site and their work.) Some videos will be post frequently using my personal machine . best regards. Raheeeeb |
03-28-2007, 05:43 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | sharing of your experience is good for the user of that machine as well as it will useful to those person who is planning to purchase this or this type of machins thanks salim |
04-01-2007, 13:37 | #6 (permalink) |
No Life Poster Join Date: Apr 2005 Location: colchester Age: 56
Member: 134206 Status: Offline Thanks Meter: 17 | Hi anybody got any idea the bestway in which to remove k750i joysticks v3 charging blocks ??? these seem to be fixed to the board via solder which melts only at high temperature. Jovy syetem seems good removing plastic parts (temperature at 185)but ive took it up a lot higher but still joystick charging blocks do not move. |
04-01-2007, 20:41 | #7 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | First Vedio by me to clear how the machine safely remove any plastic parts soldered with lead free solder in nokia 6630 (bb5) PCB .... and re-mount same plastic part without any damage fastly in onther lead free board .. http://www.raheeeeb.cellphonerepair.us/ More will be soon just post any diffculties i will try upload video or steps to handle any .. but forgive me little bit delay and poor quality recording thx Raheeeeb |
04-01-2007, 21:35 | #8 (permalink) | |
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
normal flux burn in heat degree lower than solder melting heat degree keep protective covers in it's module in other side of board which exposed to lower heater. 2- Use lower heater in re flow (not fast re flow) 3- Use upper heater in fast re flow with adjusting the distance between end of part and heater 5 cm it is differ between v3 socket and k750i joystick 4- monitor the heat till 220 to 230 not less remove the upper heater and now all o.k i hope . if any you welcome to discus Raheeeeb | |
04-04-2007, 20:32 | #10 (permalink) |
No Life Poster Join Date: Jan 2002 Location: india/saudi arabia
Member: 9013 Status: Offline Thanks Meter: 15 | @raheeb, I am a new user of this mechine. so pls lean to me how i can use this mechine. sir, i can see in moniter profile 1 mode, profile 2 mode and leadfree mode, which mode i can use for mobile phone boards. pls kindly reply regards gsmbun |
04-10-2007, 21:30 | #11 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | Dear Raheeeeb, Thanks for the generosity in sharing those videos. They'll certainly help other users along with all the hints you are giving us on this and other threads! I wish more members who are expert at infra red rework would share experiences here too. Best regards, Trion |
04-14-2007, 06:31 | #13 (permalink) | |
Junior Member Join Date: Apr 2007 Location: infra planet
Member: 488313 Status: Offline Thanks Meter: 0 | hi it is 100% possible Quote:
yes it is possibe to remove epoc using jovy system but import things in hardware repairing is experince trial and error for remove glued or epoc base ic important they needed more temperature to remove the ic as far as my experince goes the glue ics is destroyed but the pcb is not so u can put another new ic but all this requires years of practice i hope u can understand regards tornado infra | |
04-24-2007, 21:04 | #15 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | @All new video uploaded in below link for Nokia 3230 Sim and MMC module The most sophisticated module in these series of phones impossible to rework or mount by hot air include many points of solder pins include plastic parts real challenge for hot air and crap IR manufacturers http://www.raheeeeb.cellphonerepair.us Sorry for bad quality more will be uploaded soon BR Raheeeeb Last edited by Raheeeeb; 04-24-2007 at 21:17. |
The Following User Says Thank You to Raheeeeb For This Useful Post: |
Jovy Rework System RE-7500 in germany or austria | Smart-bos | Wanted Products | 0 | 12-24-2007 13:57 |
JOVY SYSTEMS RE-7500 ready to sell in algeria | multimedia box | Main Sales Section | 0 | 07-19-2007 20:27 |
Re-7500 Jovi Systems | Mansoor | Hardware Equipments for GSM | 1 | 03-12-2007 23:33 |
Re-7500 Jovi Systems | G$M solution | Hardware Equipments for GSM | 4 | 02-13-2007 20:41 |
Jovy Systems RE-7500 | arsl | Forum Announcements | 38 | 01-29-2007 15:16 |
