Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 04-08-2007, 12:12   #1 (permalink)
Member: 2899
killed 3 fones with re 7500
hi
i tried to change a ribbon socket,and cherger connector on 3 different types of samsubg,after succesfuul change,none of them are turning on,i covered the bottom of the board with the foil which was supplied ,fast reflow upper and lower heater ,190 deg, what am i doing wrong?please write your experience here.
br
farry
Old 04-08-2007, 14:27   #2 (permalink)
balu_dark's Avatar
Member: 16251
try to clean all with methanol - remove flux from board. also if CPU under composite glue - phone phone can be damaged during work with it
Old 04-08-2007, 21:19   #3 (permalink)
Member: 7062
There are diffrence between deal with sockets mounted in the bottom or the top pcb and others in the middle or srounding with some compontents specailly if these were glued or underfilled.
for this you should do the following steps
1-should strictly cover all glued component around the desired part
with reflective tape
2-should apply extra solder to sockets pins on board becasue during remove the damged part some of the solder been taken with the socket legs
3-should use good flux to let the solder well melt with the new socket
4-should not start cooling after you turn the upper heater directly but you can somthly assure the jionts by a gentle touch from the tweezer to the socket .
thanks
Raheeeeb
Old 04-09-2007, 11:31   #4 (permalink)
Member: 2899
hello
i covered all of the bottom pcb with reflective tape,but i didnt cover the top board,it was samsung d500,i also checked the socket under the microscope,all seems ok,so is it ok to cover all the componnents at the bottom and at top? ru saying when in park mode, do not turn the cooling fan on?is it generally safe then if u dont exceed 180 deg,as long as glued,or most componnents r covered,thnx for the tips rahheb and balu dark.
br
farry
Old 04-14-2007, 07:18   #5 (permalink)
Member: 488313
Re 7500 Cannot Kill Anything
Originally Posted by farry View Post
hi
br
farry
hi
sir with due respect sir this device re7500 is tecnical tools
to operate any enginnering tools a certain aspect skill and experince is
required for example u must be skilled tecnician have 2 or 3 years
experince in hardware to operate a infra rework station
but killing some phones can also be good because u can gain experince
first mobile phone i repair was erricon 337 back in 1997
the cost of this mobile was 1000 usd
we could recover money with this experince
i hope u understand
regards
tornadoinfra
Old 05-03-2007, 22:28   #6 (permalink)
Member: 47384
Originally Posted by tornadoinfra View Post
hi
i hope u understand
regards
tornadoinfra
Nice words.They must unsdertand about that for sure.
Fix XBOX360 ring of death with RE-7500 Trion RE-7500 Reworking System & iSolder 131 08-22-2010 21:41
what happen with others topics about re-7500? katocarlos RE-7500 Reworking System & iSolder 1 09-29-2009 19:38
Jovy Systems RE-7500 arsl Forum Announcements 38 01-29-2007 14:16
Who is going to buy RE-7500 from Xmas Offer? Let's make a list. Pasza Forum Announcements 83 01-28-2007 22:43
Re-7500 How Good porn Hardware Equipments for GSM 1 11-09-2006 07:49
Page generated in 0.25800 seconds with 11 queries
