Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 12-19-2009, 09:55   #46 (permalink)
Member: 1181211
PCI voltage
was hoping to check the slot to see if there is a problem with incorrect voltage - the OS can see as far as the slot but says its empty
Old 12-19-2009, 15:30   #47 (permalink)
Moderator
Member: 437621
Check the solder joints on the PCI connector
Old 12-19-2009, 16:57   #48 (permalink)
Member: 1181211
tried that
i checked those with a meter - no problem on that part
- seems beyond the pci slots somewhere
Old 12-21-2009, 22:07   #49 (permalink)
Member: 44625
Here's a video that'll help: http://www.youtube.com/watch?v=aY8tV...eature=related . Even though its in Spanish, do watch it as it can help you. Hopefully someone will be able to make a more comprehensive video. But for now this can give some ideas.
B.R.
Old 12-22-2009, 15:27   #50 (permalink)
Crazy Poster
Member: 473301
WIFI Problem
In your previous quote you said you have applied force on BGA ic when reflowing, is it the ICH (south bridge), then you have to replace ICH, since ICH also controls wifi, as far as battery not charging did you check with alternate battery, is the battery getting detected by the Operating System, if so then check for 'MAX" IC (battery charging IC), this should solve your problem.
B/R
Old 12-23-2009, 02:35   #51 (permalink)
Member: 1181211
where is the battery charging IC?
on the dv6000 model motherboard which IC is responsible for charging the battery?
Old 12-23-2009, 07:33   #52 (permalink)
Member: 1034400
B.R.
good videos
more videos http://www.youtube.com/user/lokesea2006
Old 01-27-2010, 19:24   #53 (permalink)
Member: 1220654
Question
To reball this 6150 chip, one has to remove it.
How do you remove the Red Epoxie holding it down?
Is there a chemical to desolve it ?
Or is it simply chipped away after being heated?
Old 01-28-2010, 15:48   #54 (permalink)
Moderator
Member: 437621
PU8 MAX8724 is the batt charger chip.
Also suggest replacing MOSFET PQ57 SI4914DY
This is assuming an AMD board
Old 02-11-2010, 23:08   #55 (permalink)
Member: 1234021
alternates to GF6150
Guys, this forum and especially this thread is EPIC! It's delightful to read such insight! How about this question: could the Nvidia GF6150 be replaced with another member of it's family which runs cooler? I just spent 45 minutes on the phone with Nvidia tech support (India), but sadly a tech person cannot typically answer questions meant for an engineer. Perhaps one of you knowledgeable person could tell me which Nvidia product would fit the same socket (for lack of the correct term), but produce much less waste heat?
Old 02-12-2010, 03:38   #56 (permalink)
baldev's Avatar
Member: 153805
Originally Posted by discount2 View Post
Is there any relation with thread?
Old 03-10-2010, 16:13   #57 (permalink)
Moderator
Member: 437621
If you heat up the red epoxy with a hot air pencil while removing it with a fine pick, most will come off. Be very careful not to hit board with pick and damage traces. Then when removing chip, at 240c-245c it will soften the rest of the epoxy enough to remove the chip. I usually discard the chip after the excessive heat it takes to remove the epoxy and use a new chip.
Anyone else out there with different methods of removing this red epoxy?
As for the person with the wireless question. Yes the G6150 also controls the PCI express wireless circuit. So if the wireless isn't working, the G6150 is the problem.
Old 03-28-2010, 23:20   #58 (permalink)
Member: 1236849
Just to warn some people here as some of You havent got a clue about BGA and lead free.
You need at least 217C just to liquify leadfree balls.
To make reflow at least a bit reliable You need to keep the temperatue above 217C for at least 30sec with a top temp up to 230C. The whole profile needs to be properly adjusted, ramp, temp up and down, etc. This is extremely hard work and needs a lot of time and knowlegde/research. More than 230C peak temp can damage the chip pernamently. It also applies to lead solder and reballing.
To make repair completely reliabale You need a new chip from C2 or later family. Earlier versions of nvidias chip are simply badly designed and will brake sooner or later.
Best way to remove the red glue is heat gun or reballing.
Old 03-29-2010, 09:29   #59 (permalink)
Member: 132074
hi, what you mean with " C2 version chip " or later family?
Old 03-29-2010, 11:40   #60 (permalink)
Member: 1236849
Ups, I mean version D/C 09 or later. Its a manufacture date. These chips do not overheat.
6210 flash chip problem??? maciekmm Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-20-2004 18:21
6210 flash chip problem??? maciekmm Nokia Hardware & Hardware-Repair Area 1 10-19-2004 17:27
Panasonic GD67 source chip problem corale99 Hardware Repair by brands 0 10-06-2003 07:19
Source chip problem on Panasonic GD67 corale99 Panasonic 0 10-03-2003 22:30
GF768 flash chip problem looker Hardware Repair by brands 0 03-08-2002 06:09
Page generated in 0.74295 seconds with 12 queries
