Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 01-22-2011, 19:23   #121 (permalink)
Member: 1461747
Take a look at this: why-nvidia-chips-defective
Thats why i search bga that are manufactured in 2008 or later. This problem is not fixable and maybe the reason why my fixed units fails after a couple of months.
But where can i get those new bga's? What datecode is on the bga that is manufactured after 2008?
Sorry for the double post, but i can't see my entry for hours.
Old 01-27-2011, 18:10   #122 (permalink)
Member: 44625
The most important thing i'm trying to tell all people is that most machines that cost under 2000 USD can't show the temperature accurately. So what the machine shows may not be the actual temperature. I find that my machine shows 7-10 degrees less than the actual component temperature. This can be verified by using a second temperature probe like some others on this forum or by using an infra red thermometer.
Good quality genuine flux is necessary for rework.
B.R.
Old 01-28-2011, 15:38   #123 (permalink)
Member: 1242964
Hi Trion,
What in your opinion is good flux? I tried many brands like Amtech, Kester, Kingbo.
For reballing i prefer the kingbo. For reflowing i prefer the Amtech 223
TPD-UV All for leaded solder.
The Amtech was genuine. Not the fake they sell on Ebay.
Old 01-29-2011, 08:22   #124 (permalink)
Crazy Poster
Member: 473301
Originally Posted by monitron View Post
Hi Trion,
hi, use interflux, belgium, ILF8300 BGA tacky gel flux, it is very good.
The Following User Says Thank You to pentu For This Useful Post:
Old 01-29-2011, 15:41   #125 (permalink)
Member: 1242964
Thanks, i found the website and will order it monday. Let you know what i think about it.
Old 02-20-2011, 14:27   #126 (permalink)
Angello's Avatar
Member: 19927
Sonork: joe-lindien
Originally Posted by ShadowmanX View Post
1) better look into some tools at price about 24k GBP or 29k EUR - it is nearest true
29000€ or 2900€ ? But it is the same,your word are wrong.For make a repair it is not necessary to pay a tools with lots of money if you are a good technician.
2) If U do not change broken chip - Your work is vain...
How to know if it is broken?
Wrong a good reball can repair problem.
3) If chip's connection broken and U cannot resolder it correctly - Your work is vain...
You have right.
4) If U do not resolve cooling and mechanical problem - Your work is vain...
Maybe but...A good thermal can help too.
Old 02-25-2011, 06:05   #127 (permalink)
Member: 301521
7600
i have a mbx-149 vaio 7600gpu motherboard.
gpu chip fall down from pump during remove.
5 or 6 resistors mixed there.
it is near gpu crystal.
anyone have that motherboard can upload a picture of gpu side of this mobo?_
it does not matter 7600 or g73 same mobo. just mbx-149
i googled and saw many pictures but i can't see resistors on any picture. and pictures on internet is very small. i have already search alibaba, aliexpress, taobao, ebay, and other sites. cant find a good image.
im waiting a big image of gpu side. i need to fix that problem and dont have time. tomorrow customer will come and im confused with that resistors.
already thanks for help.
Old 02-28-2011, 19:51   #128 (permalink)
Member: 1285693
i should have a few of these kicking around the workshop, if no one beats me to it i will upload an image.
worked on quite a few of these over last few years, and only ever needed to reflow them.
Old 03-01-2011, 05:19   #129 (permalink)
Member: 301521
hy
thanks 4 reply.
i ll wait.
Old 03-01-2011, 12:32   #130 (permalink)
Member: 1285693
Old 03-01-2011, 18:03   #131 (permalink)
Member: 301521
hey
thanks 4 reply and 4 image.
but it is dv9000
i mean left side of gpu. (motherboard)
no problem. i will take back that computer to customer.
Old 03-01-2011, 18:40   #132 (permalink)
Member: 1285693
ah sorry I misread it. I thought you had knocked the resistors off the top of the GPU, and well spotted it is a DV9000. Think the only sony board I have is a MBX-160.. But if I one first thing in the morning I will get a picture up.
The Following User Says Thank You to Kujoy For This Useful Post:
Old 03-02-2011, 07:15   #133 (permalink)
Member: 301521
hi
you try to help. thanks. i wish help you too if you have problem with any notebook board and any problem.
Old 03-09-2011, 08:52   #134 (permalink)
Member: 301521
hi
hi all,
here new problem
no luck on all sis m672 chipsets with clevo 762 motherboards.
i try reball, used chips, new chips... no luck.
the real problem was, when i press on chipset little bit, it works. i changed chipsets but no luck.
ever no luck all on sis chipsets.
any suggestions?
Old 03-10-2011, 09:20   #135 (permalink)
Member: 1242964
Hi,
I had some problems with this chip in the beginning. Now i put kapton tape on the metal part of the chip. Then i preheat to 120 degrees and then reflow.
Very important is that you keep the time between liquid longer as usual. I use 70-80 secs. But keep your eye on the max temp during that time.
Make sure your have only one unkown factor. What i mean is that you could have corrupted the bios and are focussing on the chip.
HTH
6210 flash chip problem??? maciekmm Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-20-2004 18:21
6210 flash chip problem??? maciekmm Nokia Hardware & Hardware-Repair Area 1 10-19-2004 17:27
Panasonic GD67 source chip problem corale99 Hardware Repair by brands 0 10-06-2003 07:19
Source chip problem on Panasonic GD67 corale99 Panasonic 0 10-03-2003 22:30
GF768 flash chip problem looker Hardware Repair by brands 0 03-08-2002 06:09
Page generated in 0.47009 seconds with 12 queries
