Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 07-10-2008, 20:44   #1 (permalink)
Member: 811464
Question concerning probe on re-7500
Im new to this forum and I have recently purchased
a RE-7500 from Jovy systems.I am presently working
with it and found a problem with the temperature probe.
I did some work on some boards and the temp that is
indicated is always too low.If I see 120 celsius I check
with a temp mutimeter and probe and I read 240 degrees.
I know that the temp is higher than 120 because all the
chips are easy to pickup.I bought an infra red temp gun and
also a calibrator.Using a omega cl-300 thermo couple
simulator I checked the k input on the RE-7500 and the
tests ,from 0 to 500 degrees ,all pass showing the correct temp.
Using a compatible probe for a test gives me better
readout than the probe from Jovy.Has anyone checked the
precision of the Jovy RE-7500 temperature probe?
I cant use profiles with the probe presently because it
gives me almost an error of 100 gegrees celcius .If I use the profile2
from the machine for north and south bga the board will burn.
I already did a test with a scrap logic board and using the
infra red gun I got up to almost 300 degrees celsius before the
display showed 180 degrees on the screen.
I contacted Jovy but response is slow.I saw that allot of
people were using this machine on this forum and it convinced
me to buy it directly from Jovy.
Thanks.
Old 07-11-2008, 01:42   #2 (permalink)
Member: 811464
Found probe answer
Just found proper way of adjusting probe
from photos sent by Jovy and also turn
off all ceiling fans and air flow that can affect sensor
...it is very sensitive .Profiles work correctly now.
The Following User Says Thank You to prbzorba For This Useful Post:
Old 02-19-2009, 17:21   #3 (permalink)
Member: 964061
How did you adjust it? Mine also reads very low, though the circuitry seems accurate. It looks to me as if the probe is simply not at the board temperature, even when the probe is touching the board.
Hal
Old 02-22-2009, 22:48   #4 (permalink)
Member: 964061
I don't suppose you could post the photos Jovy sent you. If you look at all the Omega surface probes (and they are really experts at measuring temperature), they go to great pains to keep their probes flat on the surface whose temperature is being measured, while the Jovy probe just has a tiny point of contact. It's bound to be hard to measure the surface temperature with so little contact.
Since I couldn't get a response from Jovy (or the US distributor, to whom Jovy sent my inquiry---he just sent a nasty message telling me to get lost), I'll have to make my own probe with a better surface contact.
who's recieved the RE-7500... acyl2000 Forum Announcements 74 04-11-2007 15:31
Jovy Systems RE-7500 arsl Forum Announcements 38 01-29-2007 14:16
Who is going to buy RE-7500 from Xmas Offer? Let's make a list. Pasza Forum Announcements 83 01-28-2007 22:43
Re-7500 cellularmedic The Market Feed Back 2 01-20-2007 07:54
Re-7500 How Good porn Hardware Equipments for GSM 1 11-09-2006 07:49
Page generated in 0.29242 seconds with 11 queries
