Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 10-10-2007, 04:27   #1 (permalink)
sifou474's Avatar
Member: 60699
which is the size of the surface that jovy can heat?
which is the size of surface that jovy RE-7500 can rework?
is it possible to replace DIMM socket of a pc motherboard using RE-7500??
Old 10-10-2007, 21:36   #2 (permalink)
Member: 4249
They write in their website :
Max board Size : 350mm x 450 mm
http://www.jovy-sys.com/videos/RE7500_NB.wmv
Old 10-11-2007, 19:29   #3 (permalink)
Member: 44625
I have reflowed chipsets on motherboards and recently i have reflowed an xbox360's processor and GPU successfully and got it working. I think you should be able to remove a DIMM socket with some ingenuity. I too was curious about this. If some people can do it with hotair, why not with infrared? Do either of you guys fix motherboards too?
Old 10-16-2007, 01:30   #4 (permalink)
Member: 7062
1-use your solder iron and wick to remove the solder joints from teh lower side
2-use for ramp stage the preheater till it become 80 degree in park mode adjusted in re flow
3-use also the lower heater for the preheating stage till it become 120 degree
4-soak and removal you should use upper heater hight at 8 cm from your target for 1 minutes upper heater in re flow mode and preheater in reflow mode also when temp reach 180 -185 your socket should be removed you have to use hard strong tweezer.
Thank you
Raheeeeb
Old 10-19-2007, 02:35   #5 (permalink)
Member: 597224
Good work Man And i Hope To Go To The Better
How is the size of E770 FULL FLASH ? asmodi NSPRO 0 01-20-2009 14:44
what is the name of the application that? moose_1980w Nokia Multimedia 3 11-15-2005 09:44
what is the size of m55 flash chip? MrGoo mobile E-Gold Based Phones 6 01-30-2004 22:18
3310 --> 3315 Why the size of PPM MCU is so small? Fluke Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-06-2002 04:28
How do I use an Hex Editor to Modify the Size of the Flash File simbirley Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 09-19-2001 11:03
Page generated in 0.23752 seconds with 11 queries
