Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2002 Location: Poland
Member: 15521 Status: Offline Thanks: 40
| What temperature for remove BGA? Hello What temperature I must set for remove BGA on the PB tin, and what for withut PB tin? (170 - for PB) and (225 for without PB) is good? Regards ****** |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2001 Location: -------- Age: 44
Member: 7062 Status: Offline Thanks: 0
| For lead free answer is yes but you have to give teh board teh preheating stage for 1 minute at least preheat image is 90 C For leaded you might face boards need up to 185 depend in teh solder mix used might use sliver (Ag) sn63pb36Ag1 Br Raheeeeb |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2002
Member: 10679 Status: Offline Thanks: 9
| My information id about hot air stations, please delete if it is incorrect.. Your values are correct for the temperature at the PCB. But the temp set at the heater unit is not the same as on the PCB! With BGA you are heating the balls through the IC package, which causes further temperature losses, plus the PTC sensor is not in at the end of the exhaus pipe in most models, you are just setting the temperatur of the air heating element. On my hot air stations (JBC AM-6000 & AOYUE-852A) for PB free I use 350C setting, for PB around 330C. Last edited by doggyfreestart; 09-19-2007 at 15:43. |
| | #4 (permalink) | |||
| Quote:
Also refer to Ok international micro oven theory for hot air APR 5000 dz (please refer to nozzle design section) BR. Raheeeeb On my hot air stations (JBC AM-6000 & AOYUE-852A) for PB free I use 350C setting, for PB around 330C. | |||
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| what is good temperature for tp of siemens cf110 | JAVA Good | Siemens Hardware Repair Area | 0 | 08-27-2006 14:06 |
| what is the ideal temperature for hotair? | sapatos | Hardware Repair by brands | 8 | 08-30-2005 09:52 |
| Bga kit rebbal for new bga ..... | sergioems | Hardware Equipments for GSM | 12 | 11-18-2004 10:22 |
| lcd a300 what temperature!!! | sergioems | Hardware Repair by brands | 4 | 10-13-2002 19:59 |
