Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2001 Location: -------- Age: 44
Member: 7062 Status: Offline Thanks: 0
| For re flow or solder Nvidia settings are: Pre heating Upper heater OFF Lower Heater Fast Re flow Upper Heater level is 4. Machine in Normal Mode Preheating end temperature C Soak Upper heater Fast re flow Lower Heater Re flow Upper Heater level is 4. Machine in Normal Mode Soak end temperature 140 C Re flow and Soak to peak at 185 C Upper heater Re flow Lower Heater Preheat Upper Heater level is 3. Machine in Normal Mode Re flow end temperature 185 C These settings for Tin/Lead 64/36 not for lead free , T/C used in bended end not straight |
| The Following 2 Users Say Thank You to Raheeeeb For This Useful Post: |
| | #3 (permalink) |
| Junior Member ![]() Join Date: Jul 2009 Location: FRANCE
Member: 1083488 Status: Offline Thanks: 0
| thank you for your prompt response. The maximum temperature is 185 ° C, it does not need to apply between 217 and 230 for a perfect fusion ? many thanks |
| | #4 (permalink) |
| @Uncleseb It is mentioned clearly that these steps for Tin/Lead 64/36 - Not lead free , i use to reball the lead free chips to Tin/Lead to aviod any thermal stress on the chip bonds and chip levels, during rework or reballing. For Lead free you can chnage the end temperatures to be for pre heat 100 C , soak 165 C and teh reflow or final stage is 205 C. T/C in bended end BR// |
| | #5 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Mar 2007
Member: 473301 Status: Offline Thanks: 6
| Original factory fitted NVIDIA ic on the board has leadfree profile and melts at 215C if the ic is replaced normally it will be with leadbased 63/37 combination as raheeeb said leadbased is better. |
| | #6 (permalink) |
| i have altered the default profile given by JOVY to leadbased 185C, lead free 215C. it is working perfectly for me for reflows and BGA iC replacement, i have done lot of reflows and BGA ic replacement with nearly 95% success in reflow & IC replacement, some times reflows and Ic replacement will be successfull but display wont coming on because of some other problem on the MOBO, pls check that, one more advice while reflow or removing ic, remove the glue around the ic then apply flux around the BGA ic, then use hot air soldering and desoldering gun to **** the flux slowly under the BGA ic, this technique will enhance the wetting of the BGA balls under the IC and success of reflow is high |
| | #8 (permalink) |
| JOVY is a good machine it is a poor mans BGA machine, it has its own draw backs & errors but if you identify those handling wont be a problem and it will help you a lot in your business but not a heavy duty machine like its seniors more professional (high cost) BGA rework machine. |
| | #9 (permalink) |
| Moderator ![]() Join Date: Jan 2007
Member: 437621 Status: Offline Thanks: 6
| Raheeeeb, great info as usual, much appreciated, but you omitted the Preheating end temperature value. While I have your ear, one more thing. Would you remove the lead free solder from a new nVIDIA chip and reball with leaded solder? TNX, Dan |
| | #10 (permalink) | |
| Quote:
Pre heat mentioned in the second post , change leaded with the leadfree solder - why not ? | |
| | #11 (permalink) |
| Raheeeeb, Preheat temp in second post is for lead free. what about the leaded pre heat temp Also, I assume you meant that it is a good practice to replace the lead free with leaded solder whenever possible. Only downside I see maybe a possible thermal breakdown by having to heat up chip 3 times instead of once. |
| | #12 (permalink) |
| @ Dan Collins Pre heating for the leaded is 80 C . I meant to replace the Lead free solder Joints with Leaded One. It works Do you use the Large PCB supporter JV-LSU ? Regards to all |
| | #13 (permalink) |
| What is JV-LSU? Is this a Jovy accessory that is optional for larger pcb? I do have a very large pcb holder from Zephyrtronics that holds up to 22" board. Why do you ask? |
| | #14 (permalink) | |
| Quote:
22" it is different From ABC-2 20" x 18 " ? regards | |
| | #15 (permalink) |
| Raheeeb - Did some research on the JV-LSU and I see what it is now and I immediately ordered one. It is a new item and I see it as a must have item for doing motherboards. I may order a 2nd one for the bigger boards. Now if they had a top support to clamp over the JV-LSU lower support, then that would be ideal. Jovy also has a new small board supporter JV-SSU for anyone interested in doing very small boards. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how can i define wich file have wich languge | waqas_ali601200 | Universalbox | 6 | 03-16-2010 10:34 |
| Wich Module to use ? Wich PACK ? Wich supported Models ? PLEASE READ | FuriouS TeaM | FuriouS TeaM Products | 0 | 04-18-2008 08:00 |
| ..::Software::.. Wich cable for Wich Samsung | GsmTower | Samsung Flashers, Software, Firmware. | 30 | 07-13-2006 15:19 |
| Change Imei On X480, Wich Cable Wich Program | latemer | Samsung Flashers, Software, Firmware. | 1 | 04-11-2006 16:19 |
| Wich softvare is the most old wich is not cracked | gsminstructor | Off Topic Zone | 11 | 12-31-2004 12:09 |
